After doing a dist-upgrade from 20.04 to 20.10, I now have broke NVidia drivers that can't be reinstalled. No matter what I do, it ends with:
 nvidia-driver-460 : Depends: libnvidia-compute-460 (= 460.67-0ubuntu0~0.20.10.1) but 460.73.01-0ubuntu1 is to be installed
                     Depends: libnvidia-decode-460 (= 460.67-0ubuntu0~0.20.10.1) but it is not going to be installed
                     Depends: libnvidia-encode-460 (= 460.67-0ubuntu0~0.20.10.1) but it is not going to be installed
                     Recommends: nvidia-settings but it is not going to be installed
                     Recommends: nvidia-prime (>= 0.8) but it is not going to be installed
                     Recommends: libnvidia-compute-460:i386 (= 460.67-0ubuntu0~0.20.10.1)
                     Recommends: libnvidia-decode-460:i386 (= 460.67-0ubuntu0~0.20.10.1)
                     Recommends: libnvidia-encode-460:i386 (= 460.67-0ubuntu0~0.20.10.1)
                     Recommends: libnvidia-ifr1-460:i386 (= 460.67-0ubuntu0~0.20.10.1)
                     Recommends: libnvidia-fbc1-460:i386 (= 460.67-0ubuntu0~0.20.10.1)
                     Recommends: libnvidia-gl-460:i386 (= 460.67-0ubuntu0~0.20.10.1)
The important part seems to be Depends: libnvidia-compute-460 (= 460.67-0ubuntu0~0.20.10.1) but 460.73.01-0ubuntu1 is to be installed
I tried all kinds of things found in order answers, such as re-adding the ppa and
Tried putting all dependencies in one line:
sudo apt install libnvidia-common-440 libnvidia-compute-460 libnvidia-decode-460 libnvidia-encode-460
Tried:
sudo apt-add-repository ppa:graphics-drivers/ppa
ubuntu-drivers devices
sudo apt install nvidia-driver-460
Tried rebuilding souces:
sudo rm /etc/apt/sources.list
sudo software-properties-gtk
then selecting all sources again and sudo apt-get update && sudo apt-get dist-upgrade -y, but Same issue.
Also tried:
sudo apt -f install
No difference.
Then I tried:
sudo apt remove nvidia*
sudo apt autoremove
sudo ubuntu-drivers autoinstall
But same result.
How can I fix this?
Maybe this nvidia driver is not compatible with the latest kernels. You can find info about legacy drivers on Nvidia's website : https://www.nvidia.com/en-us/drivers/unix/legacy-gpu/
You may have several solutions depending on your hardware (and kernel).
1/ remove nvidia's drivers and install the ubuntu kernel's generic display driver
sudo  systemctl  stop  lightdm.service
sudo apt purge '^nvidia-*'
sudo apt install xserver-xorg-video-nouveau
sudo reboot now
2/ replace nvidia-driver-460 by another one from Ubuntu which is likely to be compatible with your GPU and still maintained for your kernel; you may browse the documentations like :
3/ try another driver from Nvidia which is compatible with your hardware; nvidia provides compatibility info and downloads :
The first solution seems easier but may not allow to get benefit of all features of your hardware.
I hope that will help...
What I have seen is that the makefiles of some nvidia modules contain a very sketchy
CC=cc
line and then proceed with compilations that issue gcc specific commands and directives to build their modules during installation. I suspect that whatever generated that makefile is not aware that cc is a placeholder for the system's default C compiler and that it is not required to be gcc.
Some people prefer clang over gcc, so they override their systen's default compiler. If the module build scripts assume you're using gcc, some packages will be configured incorrectly and cause problems when installing drivers. I've had this issue before with nvidia drivers.
So if you changed cc to something of your choosing, you should try setting cc back to gcc temporarily using
update-alternatives --config cc
as root, and select gcc (usually option 0). Then retry the driver installation. Don't forget to change it back to what you had before when you're done.
And no
CC=gcc apt install nvidia-driver-<version>
sadly does not work.
rhb
