I have upgraded from Ubuntu 20.10 to 21.04 and now when I run:
sudo apt update
sudo apt-get upgrade
I get this error below related to PostFix.
How can I solve this problem?
Hit:1 http://archive.ubuntu.com/ubuntu hirsute InRelease
Hit:2 http://archive.ubuntu.com/ubuntu hirsute-updates InRelease
Hit:3 http://archive.ubuntu.com/ubuntu hirsute-backports InRelease
Hit:4 http://archive.ubuntu.com/ubuntu hirsute-security InRelease
Reading package lists... Done
Building dependency tree... Done
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
gcc-10-base:i386 gnome-shell-extension-desktop-icons libaom0:i386 libaribb24-0:i386 libasync-mergepoint-perl libavcodec-extra58:i386 libavutil56:i386
libboost-date-time1.71.0 libboost-filesystem1.71.0 libboost-iostreams1.71.0 libboost-locale1.71.0 libboost-python1.71.0 libbrlapi0.7 libcodec2-0.9:i386
libdav1d4:i386 libfuture-perl libgdk-pixbuf-xlib-2.0-0:i386 libgdk-pixbuf2.0-0:i386 libgomp1:i386 libio-async-loop-epoll-perl libio-async-perl libisl22 libjs-sizzle
libjuh-java libjurt-java liblibreoffice-java liblinux-epoll-perl libmetrics-any-perl libmp3lame0:i386 libmysqlclient21 libmysqlclient21:i386 libnuma1:i386
libopencore-amrnb0:i386 libopencore-amrwb0:i386 liborcus-0.15-0 liborcus-parser-0.15-0 libperl5.30 libperl5.30:i386 libpgm-5.2-0 libpodofo0.9.6 libpoppler102
libpoppler102:i386 libpython3.8-dev libraw19 libre2-8 libreadline5 libridl-java libsereal-perl libshine3:i386 libsnappy1v5:i386 libsnmp35 libsnmp35:i386
libsoxr0:i386 libspeex1:i386 libstd-rust-1.47 libstruct-dumb-perl libswresample3:i386 libtest-fatal-perl libtest-metrics-any-perl libtest-refcount-perl
libtwolame0:i386 libunoloader-java libvdpau1:i386 libvo-amrwbenc0:i386 libvpx6:i386 libwavpack1:i386 libwebpmux3:i386 libx264-160:i386 libx265-192:i386
libxml-writer-perl libxvidcore4:i386 libzvbi0:i386 linux-headers-5.8.0-49 linux-headers-5.8.0-49-generic linux-image-5.8.0-49-generic linux-modules-5.8.0-49-generic
linux-modules-extra-5.8.0-49-generic mesa-vdpau-drivers:i386 mysql-common node-ansi-align node-arrify node-bl node-bluebird node-boxen node-builtin-modules
node-call-limit node-camelcase node-ci-info node-cli-boxes node-cliui node-co node-concat-stream node-config-chain node-configstore node-cross-spawn
node-crypto-random-string node-cyclist node-debbundle-es-to-primitive node-decamelize node-decompress-response node-deep-extend node-define-properties
node-detect-indent node-detect-newline node-dot-prop node-duplexer3 node-duplexify node-editor node-end-of-stream node-errno node-es-abstract node-es6-promise
node-execa node-find-up node-flush-write-stream node-from2 node-fs-vacuum node-genfun node-get-caller-file node-get-stream node-got node-has-symbol-support-x
node-has-to-string-tag-x node-import-lazy node-invert-kv node-is-buffer node-is-npm node-is-obj node-is-object node-is-path-inside node-is-plain-obj
node-is-retry-allowed node-is-stream node-isurl node-jquery node-json-buffer node-kind-of node-latest-version node-lazy-property node-lcid node-libnpx
node-locate-path node-lodash node-lodash-packages node-lowercase-keys node-make-dir node-mem node-merge-stream node-mimic-fn node-mimic-response node-minimist
node-mississippi node-npm-run-path node-object-inspect node-os-locale node-os-tmpdir node-p-cancelable node-p-finally node-p-is-promise node-p-limit node-p-locate
node-p-timeout node-package-json node-parallel-transform node-path-exists node-path-is-inside node-pify node-prepend-http node-proto-list node-prr node-pseudomap
node-pump node-pumpify node-qw node-rc node-registry-auth-token node-registry-url node-require-directory node-require-main-filename node-semver-diff node-sha
node-shebang-command node-shebang-regex node-slide node-sorted-object node-stream-each node-stream-iterate node-stream-shift node-strict-uri-encode node-strip-eof
node-strip-json-comments node-term-size node-through2 node-timed-out node-typedarray node-uid-number node-unique-string node-unpipe node-url-parse-lax
node-url-to-options node-which-module node-widest-line node-wrap-ansi node-xdg-basedir node-xtend node-y18n node-yargs node-yargs-parser ocl-icd-libopencl1:i386
perl-modules-5.30 python3.8 python3.8-dev python3.8-minimal python3.8-venv shim ure-java vdpau-driver-all:i386
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up postfix (3.5.6-1) ...
Postfix (main.cf) configuration was not changed. If you need to make changes,
edit /etc/postfix/main.cf (and others) as needed. To view Postfix
configuration values, see postconf(1).
After modifying main.cf, be sure to run 'systemctl reload postfix'.
Running newaliases
newaliases: warning: valid_hostname: misplaced delimiter: kubernetes-worker..
newaliases: fatal: file /etc/postfix/main.cf: parameter myhostname: bad parameter value: kubernetes-worker..
dpkg: error processing package postfix (--configure):
installed postfix package post-installation script subprocess returned error exit status 75
Processing triggers for libc-bin (2.33-0ubuntu5) ...
postfix
