I have Ubuntu 20.04.2. I can't seem to install packages that require dependencies.
There are many packages I have to install with puppet, this is what of them:
~# apt install aptitude
Reading package lists... Done
Building dependency tree
aptitude : Depends: libapt-pkg5.0 (>= 1.1) but it is not going to be installed
Recommends: libparse-debianchangelog-perl but it is not going to be installed
This is what I tried:
apt update && apt upgrade
apt autoremove
apt-get -f install
dpkg --configure -a
apt dist-upgrade
rm /etc/apt/sources.list.d/*
apt-mark showhold #shows nothing
apt install aptitude --fix-missing
Nothing works. I keep getting the error in the first code snippet. All the commands I ran above seem to have worked for other people online.
Does anyone happen to know how to fix it? Huge thanks ahead!
EDIT: I think it's related to the fact that my sources.list point to a local clone of an ubuntu 18 repo. So I deleted everything and added just the offical one, but I still get an error:
E: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal/universe/binary-amd64/Packages Cannot initiate the connection to archive.ubuntu.com:80 (91.189.88.152). - connect (101: Network is unreachable) Cannot initiate the connection to archive.ubuntu.com:80 (91.189.88.142). - connect (101: Network is unreachable)
E: Some index files failed to download. They have been ignored, or old ones used instead.
But I guess that's a separate issue though.
