Whenever I try to install wine64, it tells me to remove important packages and I don't know how to solve this.
Installing wine64 results with the procedure below:
$ sudo apt install wine64
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
apache2-data apache2-utils ethtool git-man gparted-common hwloc ieee-data liba52-0.7.4 libapr1 libaprutil1 libaprutil1-dbd-sqlite3
libaprutil1-ldap libass9 libbs2b0 libcdio19 libdazzle-1.0-0 libdvdread8 libegl1-mesa liberror-perl libfftw3-double3 libflite1
libgtkglext1 liblilv-0-0 liblinear4 liblua5.2-0 libmpeg2-4 libmysofa1 libnorm1 libopencore-amrnb0 libopencore-amrwb0 libpango-perl
libpangox-1.0-0 libpcre16-3 libpcre32-3 libpgm-5.2-0 libpostproc55 librubberband2 libsepol1-dev libserd-0-0 libsidplay1v5
libsord-0-0 libsratom-0-0 libvidstab1.1 libwxbase3.0-0v5 libx264-160 libxcb-xtest0 libzmq5 lua-lpeg ndiff nmap-common python-cairo
python-gobject-2 python-pysqlite2 python-wxversion python3-bs4 python3-debconf python3-html5lib python3-lxml python3-soupsieve
python3-webencodings
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
libapt-pkg6.0 libpci3 pciutils python3-distupgrade ubuntu-release-upgrader-core wine
Suggested packages:
q4wine winbind winetricks playonlinux wine-binfmt dosbox exe-thumbnailer | kio-extras wine64-preloader
Recommended packages:
apt wine32
The following packages will be REMOVED:
aircrack-ng anydesk apache2 apache2-bin apt apt-utils code git gnome-calendar gparted gstreamer1.0-libav gstreamer1.0-plugins-ugly
libavfilter7 libblkid-dev libffi-dev libfprint-2-tod1 libglib2.0-dev libglib2.0-dev-bin libgtk2-perl libllvm9 libmount-dev
libpcre2-dev libpcre2-posix2 libpcre3-dev libpcrecpp0v5 libselinux1-dev libwxgtk3.0-gtk3-0v5 net-tools nmap python-gtk2
python-wxgtk3.0 ubuntu-desktop ubuntu-desktop-minimal ubuntu-minimal ubuntu-release-upgrader-gtk update-manager update-notifier
update-notifier-common uuid-dev vino zenmap zoom
The following NEW packages will be installed:
wine wine64
The following packages will be upgraded:
WARNING: The following essential packages will be removed.
This should NOT be done unless you know exactly what you are doing!
apt
5 upgraded, 2 newly installed, 42 to remove and 37 not upgraded.
Need to get 1,311 kB of archives.
After this operation, 700 MB disk space will be freed.
You are about to do something potentially harmful.
To continue type in the phrase 'Yes, do as I say!'
Performing sudo apt update && upgrade results with:
Hit:1 http://downloads.metasploit.com/data/releases/metasploit-framework/apt lucid InRelease
Hit:2 http://in.archive.ubuntu.com/ubuntu focal InRelease
Hit:3 http://in.archive.ubuntu.com/ubuntu focal-updates InRelease
Hit:4 http://in.archive.ubuntu.com/ubuntu focal-backports InRelease
Hit:5 http://ppa.launchpad.net/gezakovacs/ppa/ubuntu focal InRelease
Hit:6 http://security.ubuntu.com/ubuntu focal-security InRelease
Hit:7 http://dl.google.com/linux/chrome/deb stable InRelease
All packages are up to date.
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Wine installation:
Suggested packages:
wine
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 51.9 kB of archives.
After this operation, 197 kB of additional disk space will be used.
Get:1 http://in.archive.ubuntu.com/ubuntu focal/universe amd64 wine all 5.0-3ubuntu1 [51.9 kB]
Fetched 51.9 kB in 0s (348 kB/s)
Selecting previously unselected package wine.
(Reading database ... 276005 files and directories currently installed.)
Preparing to unpack .../wine_5.0-3ubuntu1_all.deb ...
Unpacking wine (5.0-3ubuntu1) ...
Setting up wine (5.0-3ubuntu1) ...
Processing triggers for man-db (2.9.1-1) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
Processing triggers for wine (5.0-3ubuntu1) ...
wine
it looks like wine32 is missing, you should install it.
as root, please execute "apt-get install wine32"
Usage: wine PROGRAM [ARGUMENTS...] Run the specified program
wine --help Display this help and exit
wine --version Output version information and exit
After this error, I was also trying to install wine32 which resulted with a dependency error:
$ sudo apt install wine32
wine32:i386 : Depends: libwine:i386 (= 5.0-3ubuntu1) but it is not going to be installed
Then, when I try to install libwine:i386 in order to solve the dependency problem, I receive this broken package problem:
$ sudo apt install libwine:i386
libwine:i386 : Depends: libfontconfig1:i386 (>= 2.12.6) but it is not going to be installed
Depends: libfaudio0:i386 (>= 19.06.07) but it is not going to be installed
Depends: libglib2.0-0:i386 (>= 2.12.0) but it is not going to be installed
Depends: libgphoto2-6:i386 (>= 2.5.10) but it is not going to be installed
Depends: libgstreamer-plugins-base1.0-0:i386 (>= 1.0.0) but it is not going to be installed
Depends: libgstreamer1.0-0:i386 (>= 1.4.0) but it is not going to be installed
Depends: libldap-2.4-2:i386 (>= 2.4.7) but it is not going to be installed
Depends: libx11-6:i386 but it is not going to be installed
Depends: libxext6:i386 but it is not going to be installed
Recommends: libcups2:i386 (>= 1.4.0) but it is not going to be installed
Recommends: libgl1:i386 but it is not going to be installed
Recommends: libglu1-mesa:i386 but it is not going to be installed or
libglu1:i386
Recommends: libgnutls30:i386 (>= 3.6.5) but it is not going to be installed
Recommends: libosmesa6:i386 (>= 10.2~) but it is not going to be installed
Recommends: libsane:i386 (>= 1.0.24) but it is not going to be installed
Recommends: libsdl2-2.0-0:i386 (>= 2.0.10) but it is not going to be installed
Recommends: libxcomposite1:i386 (>= 1:0.4.5) but it is not going to be installed
Recommends: libxcursor1:i386 (> 1.1.2) but it is not going to be installed
Recommends: libxfixes3:i386 but it is not going to be installed
Recommends: libxi6:i386 but it is not going to be installed
Recommends: libxinerama1:i386 but it is not going to be installed
Recommends: libxrandr2:i386 but it is not going to be installed
Recommends: libxrender1:i386 but it is not going to be installed
Recommends: libxxf86vm1:i386 but it is not going to be installed
Recommends: libgl1-mesa-dri:i386 but it is not going to be installed
Recommends: gstreamer1.0-plugins-good:i386 but it is not going to be installed
I also tried other tutorials to install winehq-stable but it say it has unmet dependencies.
$ sudo apt install --install-recommends winehq-stable
winehq-stable : Depends: wine-stable (= 6.0.0~focal-1)
I did aptitude also it recommended to leave wine32 packages as it is. So it is not doing anything if the solution is approved. What should I do?
