I was using a built-in monitor of my laptop and two external displays connected to it installed with Ubuntu 20.04 LTS.
I had to reinstall OS for some reason. After re-installation, only two monitors are available and 3rd display is not detected.
Problem
- I can use only one external display. The other is not detected.
- second external display is not shown in
Setting -> Displaysof Ubuntu andnvidia-settings -> X Server Display Configuration -> Detect Displays.
- When I first plug one external display, it works correctly. If I then plug the other external display, the first one disappears and the latter works.
- I want to use a built-in display and two external displays at the same time, which worked well before re-installation.
Information
PC: Lenovo Thinkpad T490, Intel Core-i5
GPU: GeForce MX250
OS/kernel: Ubuntu 20.04 LTS / 5.8.0-50-generic
- my laptop has two USB-C ports and one HDMI port. Monitor A is connected via HDMI-HDMI cable, and monitor B is connected via USB-USB cable. Both works well when connected alone.
- output of
xrandr -qwhen two external displays are connected:
Screen 0: minimum 8 x 8, current 2463 x 2160, maximum 32767 x 32767
eDP-1-1 connected primary 1920x1080+543+1080 (normal left inverted right x axis y axis) 309mm x 174mm
1920x1080 60.05*+ 60.01 59.97 59.96 59.93
1680x1050 59.95 59.88
1600x1024 60.17
1400x1050 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 60.02
1440x900 59.89
1400x900 59.96 59.88
1280x960 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1360x768 59.80 59.96
1280x800 59.99 59.97 59.81 59.91
1152x864 60.00
1280x720 60.00 59.99 59.86 59.74
1024x768 60.04 60.00
960x720 60.00
928x696 60.05
896x672 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
960x540 59.96 59.99 59.63 59.82
800x600 60.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
800x512 60.17
700x525 59.98
800x450 59.95 59.82
640x512 60.02
720x450 59.89
700x450 59.96 59.88
640x480 60.00 59.94
720x405 59.51 58.99
684x384 59.88 59.85
680x384 59.80 59.96
640x400 59.88 59.98
576x432 60.06
640x360 59.86 59.83 59.84 59.32
512x384 60.00
512x288 60.00 59.92
480x270 59.63 59.82
400x300 60.32 56.34
432x243 59.92 59.57
320x240 60.05
360x202 59.51 59.13
320x180 59.84 59.32
DP-1-1 disconnected (normal left inverted right x axis y axis)
HDMI-1-1 disconnected (normal left inverted right x axis y axis)
DP-1-2 disconnected (normal left inverted right x axis y axis)
HDMI-1-2 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 300mm x 260mm
1920x1080 60.00 + 60.00* 50.00 59.94
1400x1050 59.95
1280x1024 60.02
1440x900 59.90
1280x960 60.00
1280x720 60.00 59.94
1440x576 50.00
1024x768 60.00
1440x480 60.00 59.94
800x600 60.32
720x576 50.00
720x480 60.00 59.94
640x480 72.81 60.00 59.94
- output of
xrandr --listproviders:
Providers: number : 2
Provider 0: id: 0x1b8 cap: 0x1, Source Output crtcs: 0 outputs: 0 associated providers: 1 name:NVIDIA-0
Provider 1: id: 0x1e0 cap: 0x6, Sink Output, Source Offload crtcs: 3 outputs: 5 associated providers: 1 name:modesetting
- output of
xrandr --listmonitors:
Monitors: 2
0: +*eDP-1-1 1920/309x1080/174+543+1080 eDP-1-1
1: +HDMI-1-2 1920/300x1080/260+0+0 HDMI-1-2
- output of
apt list --installed | grep -i nvidia:
libnvidia-cfg1-460/focal-updates,focal-security,now 460.56-0ubuntu0.20.04.1 amd64 [installed,automatic]
libnvidia-common-460/focal-updates,focal-updates,focal-security,focal-security,now 460.56-0ubuntu0.20.04.1 all [installed,automatic]
libnvidia-compute-460/focal-updates,focal-security,now 460.56-0ubuntu0.20.04.1 amd64 [installed,automatic]
libnvidia-compute-460/focal-updates,focal-security,now 460.56-0ubuntu0.20.04.1 i386 [installed,automatic]
libnvidia-decode-460/focal-updates,focal-security,now 460.56-0ubuntu0.20.04.1 amd64 [installed,automatic]
libnvidia-decode-460/focal-updates,focal-security,now 460.56-0ubuntu0.20.04.1 i386 [installed,automatic]
libnvidia-encode-460/focal-updates,focal-security,now 460.56-0ubuntu0.20.04.1 amd64 [installed,automatic]
libnvidia-encode-460/focal-updates,focal-security,now 460.56-0ubuntu0.20.04.1 i386 [installed,automatic]
libnvidia-extra-460/focal-updates,focal-security,now 460.56-0ubuntu0.20.04.1 amd64 [installed,automatic]
libnvidia-fbc1-460/focal-updates,focal-security,now 460.56-0ubuntu0.20.04.1 amd64 [installed,automatic]
libnvidia-fbc1-460/focal-updates,focal-security,now 460.56-0ubuntu0.20.04.1 i386 [installed,automatic]
libnvidia-gl-460/focal-updates,focal-security,now 460.56-0ubuntu0.20.04.1 amd64 [installed,automatic]
libnvidia-gl-460/focal-updates,focal-security,now 460.56-0ubuntu0.20.04.1 i386 [installed,automatic]
libnvidia-ifr1-460/focal-updates,focal-security,now 460.56-0ubuntu0.20.04.1 amd64 [installed,automatic]
libnvidia-ifr1-460/focal-updates,focal-security,now 460.56-0ubuntu0.20.04.1 i386 [installed,automatic]
nvidia-compute-utils-460/focal-updates,focal-security,now 460.56-0ubuntu0.20.04.1 amd64 [installed,automatic]
nvidia-dkms-460/focal-updates,focal-security,now 460.56-0ubuntu0.20.04.1 amd64 [installed,automatic]
nvidia-driver-460/focal-updates,focal-security,now 460.56-0ubuntu0.20.04.1 amd64 [installed]
nvidia-kernel-common-460/focal-updates,focal-security,now 460.56-0ubuntu0.20.04.1 amd64 [installed,automatic]
nvidia-kernel-source-460/focal-updates,focal-security,now 460.56-0ubuntu0.20.04.1 amd64 [installed,automatic]
nvidia-prime/focal-updates,focal-updates,now 0.8.16~0.20.04.1 all [installed,automatic]
nvidia-settings/focal-updates,now 460.39-0ubuntu0.20.04.1 amd64 [installed,automatic]
nvidia-utils-460/focal-updates,focal-security,now 460.56-0ubuntu0.20.04.1 amd64 [installed,automatic]
xserver-xorg-video-nvidia-460/focal-updates,focal-security,now 460.56-0ubuntu0.20.04.1 amd64 [installed,automatic]
What I did
All of them didn't work:
- install nvidia driver with apt. Below is the output of
nvidia-smi.
| NVIDIA-SMI 460.56 Driver Version: 460.56 CUDA Version: 11.2 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 GeForce MX250 Off | 00000000:2D:00.0 Off | N/A |
| N/A 55C P0 N/A / N/A | 487MiB / 2002MiB | 9% Default |
| | | N/A |
- switch between lightdm and gdm3.
- unplug and reconnect cables.
sudo ubuntu-drivers autoinstall, which had no updates or new install.- disable Secure Boot in BIOS/EFI setting.
- solution of this thread.
select-prime nvidia.- edit
/etc/gdm3/custom.conf(solution of this thread).
There are some related questions in StackExchange, but all of them didn't work for me. And I don't want to use nouveau because I experienced too many bad problems with it.
Thank you for your help in progress.
