17
i have installed nagios and i want to install nrpe. While installing NRPE, when i execute (/home/abc/nrpe/configure)
./configure
it stops after reaching the following line
checking for type of socket size... size_t
checking for SSL headers... SSL headers found in /usr
checking for SSL libraries... configure: error: Cannot find ssl libraries
I have installed libssl-dev and openssl package as i found them as a solution for this error.
I tried the following option also
./configure --with-ssl=/usr/bin/openssl --with-ssl-lib=/usr/lib
But the error remains.
What can be the possible solution for this ? I am using ubuntu 12.04 as my operating system. Thanks in advance.
this worked for me:
./configure --with-ssl=/usr/bin/openssl --with-ssl-lib=/usr/lib/x86_64-linux-gnu
I found the dir through:
apt-file search libssl | grep libssl-dev
I had similar issues on a Raspberry PI, after I'd installed the libssl-dev package
sudo apt-get install libssl-dev
but managed to find the ssl lib for the configure command with this:
# dpkg -L libssl-dev
/usr/lib/arm-linux-gnueabihf
/usr/lib/arm-linux-gnueabihf/libssl.a
/usr/lib/arm-linux-gnueabihf/pkgconfig
/usr/lib/arm-linux-gnueabihf/pkgconfig/libcrypto.pc
/usr/lib/arm-linux-gnueabihf/pkgconfig/libssl.pc
/usr/lib/arm-linux-gnueabihf/pkgconfig/openssl.pc
/usr/lib/arm-linux-gnueabihf/libcrypto.a
/usr/lib/arm-linux-gnueabihf/libssl.so
/usr/lib/arm-linux-gnueabihf/libcrypto.so
# ./configure --with-ssl=/usr/bin/openssl --with-ssl-lib=/usr/lib/arm-linux-gnueabihf
Use the following command to fix it:
yum install openssl-devel
Mithilesh
  • 81
With Ubuntu Server, try this:
Eric Carvalho
  • 55,453
