Laptop is DELL XPS 17, this does not appear to be the Atheros controller frequently mentioned on this site.
I do have a RJ45 dongle that works, so I can download what is necessary.
Bleeding edge hardware and linux... :(
sudo lshw -C network
*-network UNCLAIMED
description: Network controller
product: Qualcomm
vendor: Qualcomm
physical id: 0
bus info: pci@0000:04:00.0
version: 01
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress cap_list
configuration: latency=0
resources: memory:d2100000-d21fffff
lspci -nnk | grep 0280 -A3
04:00.0 Network controller [0280]: Qualcomm Device [17cb:1101] (rev 01)
Subsystem: Bigfoot Networks, Inc. Device [1a56:a501]
05:00.0 PCI bridge [0604]: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] [8086:15ea] (rev 06)
Kernel driver in use: pcieport
tx$ uname -r
5.8.0-25-generic
atx$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 20.10
Release: 20.10
Codename: groovy
jjs@atx$ sudo apt upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
jjs@atx$ uname -r 5.8.0-50-generic
It just stalls. Just sitting here. Htop shows no CPU activity.
jjs@atx$ sudo ubuntu-mainline-kernel.sh -i Finding latest version available on kernel.ubuntu.com Latest version is: v5.11.15, continue? (y/N)
Will download 6 files from kernel.ubuntu.com:
Downloading amd64/linux-headers-5.11.15-051115 generic_5.11.15-051115.202104161034_amd64.deb: 100%
Downloading amd64/linux-headers-5.11.15-051115_5.11.15-051115.202104161034_all.deb: 100%
Downloading amd64/linux-image-unsigned-5.11.15-051115-generic_5.11.15-051115.202104161034_amd64.deb: 100%
Downloading amd64/linux-modules-5.11.15-051115-generic_5.11.15-051115.202104161034_amd64.deb: 100%
Downloading amd64/CHECKSUMS: 100%
Downloading amd64/CHECKSUMS.gpg: 100%
Importing kernel-ppa gpg key ok
Signature of checksum file has been successfully verified
Checksums of deb files have been successfully verified with sha256sum
Installing 4 packages
Now it is just stalled, it sits there, htop shows no CPU for process.
*-network UNCLAIMED
product: Qualcomm
vendor: Qualcomm
physical id: 0
version: 01
width: 64 bits
clock: 33MHz
tx$ uname -r
5.8.0-25-generic
atx$ lsb_release -a
Release: 20.10
Codename: groovy
per https://www.how2shout.com/linux/how-to-install-linux-kernel-5-10-on-ubuntu-20-04-lts/
Ran again and it completed.
Rebooted and got:
error: /vmlinuz-5.11.15-051115-generic has invalid signature.
error: you need to load the kernel first.
Disabled Secure boot now
atx$ uname -r 5.11.15-051115-generic
atx$ sudo lshw -C
product: Qualcomm
vendor: Qualcomm
physical id: 0
version: 01
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: driver=ath11k_pci latency=0
resources: irq:196 memory:d2100000-d21fffff
atx$ lspci -nnk | grep 0280 -A3
04:00.0 Network controller: Qualcomm Device [17cb:1101] (rev 01)
Kernel driver in use: ath11k_pci
Kernel modules: ath11k_pci
atx$ lsb_release -A
Release: 20.10
Codename: groovy
But when searching for networks it doesn't show my router, which my phone sees and uses.
In addition to kernel version 5.11,you also need required firmware. Please do:
wget http://mirrors.kernel.org/ubuntu/pool/main/l/linux-firmware/linux-firmware_1.197_all.deb sudo dpkg -i linux-firmware*.deb
reboot
SUCCESS!!!
