45
I'm downloading both versions of Ubuntu 12.04 at this moment. I'd like to install AMD64 on my portable, even though it's an Intel machine. Is there a website (or another way) where I can check compatibility?
Acer Aspire 5745G-724G50Mnks, Intel i7 with 4Gb RAM
Jorge Castro
  • 73,717
GUI Junkie
  • 1,986
5 Answers5
87
To find information about your CPU including architecture, execute lscpu in terminal.
Example:
lscpu
yields ...
Architecture:          i686
CPU op-mode(s):        32-bit, 64-bit
Byte Order:            Little Endian
CPU(s):                4
On-line CPU(s) list:   0-3
Thread(s) per core:    2
Core(s) per socket:    2
Socket(s):             1
Vendor ID:             GenuineIntel
CPU family:            6
Model:                 42
Stepping:              7
CPU MHz:               2301.000
BogoMIPS:              4589.37
Virtualization:        VT-x
L1d cache:             32K
L1i cache:             32K
L2 cache:              256K
L3 cache:              3072K
For Intel systems, the Vendor ID is - GenuineIntel and for AMD - AuthenticAMD.
But they are compatible. It is a bit of an historical artifact in that AMD was the creator of the 64 bit 'long' mode, and later Intel matched that creation.
But naming often refers to any 64 bit binary as an AMD/64bit format, usually with the label 'AMD64'.
catch32
  • 1,286
  • 32
  • 43
Kempe
  • 2,805
Acer Aspire 5745G-724G50MNKS is 64 bit so you can run the amd64 download on it. I use the serial number (7545G) to google it and try to find items that included the architecture. Shops sell it with Windows 64 installed.
You will run into problems: looks like it is not 100% compatible with Ubuntu since I also found a bug report on this machine. It has amd64 stated as architecture so you can use amd64 on this.
Flimzy
  • 381
Rinzwind
  • 309,379
This is a more general but very practical answer to questions like this. We assume that we have no idea on what hardware we are, and we do not want to know anything about processors or achitecture of our system.
  • 32-bit processors are rare nowadays
  • Therefore download the am64 64-bit iso of Ubuntu and create a USB or CD boot medium
  • Boot with this and choose "Try out Ubuntu"
If that is a success and you are able to try out Ubuntu on your machine you then know for sure that your CPU is capable of running 64-bit Ubuntu. In addition you will also know that other hardware you may have is compatible. An installation will then be a success. If it fails go ahead with the 32-bit version.
Takkat
  • 144,580
you could also get it from the proc.
cat /proc/cpuinfo | grep "vendor_id"
or LSCPU as someone else already mentioned. And if you want to have a script that detects the vendor, then you could do something like the following:
vendor=$(lscpu | awk '/Vendor ID/{print $3}')
if [[ "$vendor" == "GenuineIntel" ]]; then
   echo "Intel cpu"
elif [[ "$vendor" == "AuthenticAMD" ]]; then
   echo "AMD cpu"
else
    echo "cpu vendor: $vendor"
fi
Zstack
  • 211
Use uname and sed command to get the cpu architecture.
ARCH="$(uname -m | sed -e 's/x86_64/amd64/' -e 's/\(arm\)\(64\)\?.*/\1\2/' -e 's/aarch64$/arm64/')"
echo $ARCH
You can use lscpu, awk and sed commands to find the CPU vendor i.e INTEL or AMD
lscpu | awk '/Vendor ID/{print $3}' | sed -e 's/AuthenticAMD/amd/' -e 's/GenuineIntel/intel/'
Or you can store it to a variable like
CPU_VENDOR=$(lscpu | awk '/Vendor ID/{print $3}' | sed -e 's/AuthenticAMD/amd/' -e 's/GenuineIntel/intel/')
Sks
