This what i get when i tried running this command:
dmesg | grep -i 'blue'
[ 15.207462] Bluetooth: Core ver 2.22 [ 15.207500] Bluetooth: HCI device and connection manager initialized [ 15.207504] Bluetooth: HCI socket layer initialized [ 15.207506] Bluetooth: L2CAP socket layer initialized [ 15.207509] Bluetooth: SCO socket layer initialized [ 16.680022] Bluetooth: hci0: BCM: chip id 70 [ 16.681193] Bluetooth: hci0: BCM: features 0x06 [ 16.697041] Bluetooth: hci0: Stryker [ 16.697047] Bluetooth: hci0: BCM43142A0 (001.001.011) build 0000 [ 16.932675] Bluetooth: hci0: BCM: firmware Patch file not found, tried: [ 16.932681] Bluetooth: hci0: BCM: 'brcm/BCM43142A0-0a5c-21d7.hcd' [ 16.932684] Bluetooth: hci0: BCM: 'brcm/BCM-0a5c-21d7.hcd' [ 18.962893] Bluetooth: hci0: command 0x1003 tx timeout [ 18.964047] Bluetooth: hci0: unexpected event for opcode 0x1003 [ 35.728986] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 35.728988] Bluetooth: BNEP filters: protocol multicast [ 35.728992] Bluetooth: BNEP socket layer initialized [ 38.802234] Bluetooth: hci0: command 0x1003 tx timeout [ 38.803057] Bluetooth: hci0: unexpected event for opcode 0x1003 [ 157.117857] Bluetooth: RFCOMM TTY layer initialized [ 157.117866] Bluetooth: RFCOMM socket layer initialized [ 157.117874] Bluetooth: RFCOMM ver 1.11 [ 1203.836728] Bluetooth: hci0: urb 000000003f75a935 failed to resubmit (2) [ 1226.691458] Bluetooth: hci0: BCM: chip id 70 [ 1226.692517] Bluetooth: hci0: BCM: features 0x06 [ 1226.708496] Bluetooth: hci0: Stryker [ 1226.708504] Bluetooth: hci0: BCM43142A0 (001.001.011) build 0000 [ 1226.709489] Bluetooth: hci0: BCM: firmware Patch file not found, tried: [ 1226.709493] Bluetooth: hci0: BCM: 'brcm/BCM43142A0-0a5c-21d7.hcd' [ 1226.709495] Bluetooth: hci0: BCM: 'brcm/BCM-0a5c-21d7.hcd' [ 1228.733520] Bluetooth: hci0: command 0x1003 tx timeout [ 1228.734487] Bluetooth: hci0: unexpected event for opcode 0x1003
(Any help is appreciated). Bluetooth works but doesnt detect any devices.
Pizza
  • 1,512
Stryker
  • 13
I found the solution.
I just had to download a driver and place it in the required folder.
Here is the link that I followed : Bluetooth not discovering any devices - Dell XPS 13 (16.04)
Hope it helps you :) .
Stryker
  • 13
