Environment?
Windows Subsystem for Linux.
Ubuntu 20.04
What's wrong?
apt upgrade is not working.
1.apt upgrade gives the following message
$ sudo apt upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages will be upgraded:
alsa-ucm-conf apt apt-utils curl gh isc-dhcp-client isc-dhcp-common landscape-common libapt-pkg6.0 libcurl3-gnutls libcurl4 libnss-systemd libpam-systemd libpython3.9-minimal
libpython3.9-stdlib libssl1.1 libsystemd0 libudev1 linux-libc-dev nodejs open-vm-tools openssl python3-distupgrade python3.9 python3.9-minimal systemd systemd-sysv systemd-timesyncd
ubuntu-keyring ubuntu-release-upgrader-core udev update-notifier-common
32 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
Need to get 0 B/49.1 MB of archives.
After this operation, 760 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Extracting templates from packages: 100%
Preconfiguring packages ...
Setting up libc-bin (2.31-0ubuntu9.2) ...
Aborted (core dumped)
/sbin/ldconfig.real: Can't stat /usr/local/lib/x86_64-linux-gnu: No such file or directory
/sbin/ldconfig.real: Path `/usr/lib/x86_64-linux-gnu' given more than once
/sbin/ldconfig.real: Path `/lib/x86_64-linux-gnu' given more than once
/sbin/ldconfig.real: Path `/usr/lib' given more than once
/usr/lib/x86_64-linux-gnu/libfakeroot:
libfakeroot-0.so -> libfakeroot-tcp.so
/usr/local/lib:
dpkg: error processing package libc-bin (--configure):
installed libc-bin package post-installation script subprocess returned error exit status 134
libc-bin
2."remove" gives the following message
$ sudo dpkg --remove --force-remove-reinstreq libc-bin
dpkg: error processing package libc-bin (--remove):
this is an essential package; it should not be removed
libc-bin
Reproduce?
enter link description here I referred to the link above, but it is still not solved.
