I have just added a new NVME drive to my system, I want to use it as my primary boot drive and I wanted to take the opportunity to do a cleanup of my OS.
To do that I installed a clean copy of Ubuntu 20.04 on the NVME drive with LVM and LUKS encryption. The new OS boots up fine, but now I want to copy my files over from my other drive; which was also an encrypted ssd with Ubuntu 20.04 installed.
My problem is that both drives are picked up with the same LV Path; /dev/vgubuntu/root and the same VG Name vgubuntu. I know that I could use sudo vgrename aaaaaa-aaaa-aaaa-aaaa-aaaa-aaaa-aaaaaa old-ubuntu to change the VG name of the old volume and access it, but ideally I'd like to be able to boot to both until I'm happy with the setup on the new drive.
Reading other related questions suggests that if I rename the old volume with vgrename then I won't be able to boot into it.
Running sudo lvdisplay outputs this (trimmed) and you can see that the new system root and swap are available while the old system is unavailable:
  --- Logical volume ---
  LV Path                /dev/vgubuntu/root
  LV Name                root
  VG Name                vgubuntu
  LV UUID                aaaaaa-aaaa-aaaa-aaaa-aaaa-aaaa-aaaaaa
  LV Status              NOT available
--- Logical volume --- LV Path /dev/vgubuntu/swap_1 LV Name swap_1 VG Name vgubuntu LV UUID bbbbbb-bbbb-bbbb-bbbb-bbbb-bbbb-bbbbbb LV Status NOT available ...
--- Logical volume --- LV Path /dev/vgubuntu/root LV Name root VG Name vgubuntu LV UUID cccccc-cccc-cccc-cccc-cccc-cccc-cccccc LV Status available ...
--- Logical volume --- LV Path /dev/vgubuntu/swap_1 LV Name swap_1 VG Name vgubuntu LV UUID dddddd-dddd-dddd-dddd-dddd-dddd-dddddd LV Status available ...
On other distros this answer might work. But unfortunately /dev/SysVolGroup doesn't exist on Ubuntu 20.04.
How can I mount my old LUKS encrypted volume on Ubuntu without making it unbootable?
