I want to install the xt7-player-mpv video player, which was recently updated.
It is not available for Ubuntu as deb and compiling it required Gambas3. That is available and can be installed with
sudo apt install gambas3
[sudo] password for cip:
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
  debugedit gambas3-dev gambas3-examples gambas3-gb-args gambas3-gb-cairo gambas3-gb-chart gambas3-gb-clipper gambas3-gb-complex gambas3-gb-compress
  gambas3-gb-compress-bzlib2 gambas3-gb-compress-zlib gambas3-gb-crypt gambas3-gb-data gambas3-gb-db gambas3-gb-db-form gambas3-gb-db-mysql
  gambas3-gb-db-odbc gambas3-gb-db-postgresql gambas3-gb-db-sqlite3 gambas3-gb-dbus gambas3-gb-dbus-trayicon gambas3-gb-desktop
  gambas3-gb-desktop-x11 gambas3-gb-eval-highlight gambas3-gb-form gambas3-gb-form-dialog gambas3-gb-form-editor gambas3-gb-form-mdi
  gambas3-gb-form-stock gambas3-gb-form-terminal gambas3-gb-gmp gambas3-gb-gsl gambas3-gb-gui gambas3-gb-httpd gambas3-gb-image-effect
  gambas3-gb-image-imlib gambas3-gb-image-io gambas3-gb-inotify gambas3-gb-jit gambas3-gb-logging gambas3-gb-map gambas3-gb-markdown
  gambas3-gb-media gambas3-gb-media-form gambas3-gb-memcached gambas3-gb-mime gambas3-gb-mysql gambas3-gb-ncurses gambas3-gb-net gambas3-gb-net-curl
  gambas3-gb-net-pop3 gambas3-gb-net-smtp gambas3-gb-openal gambas3-gb-opengl gambas3-gb-opengl-glsl gambas3-gb-opengl-glu gambas3-gb-opengl-sge
  gambas3-gb-openssl gambas3-gb-pcre gambas3-gb-pdf gambas3-gb-qt5-ext gambas3-gb-qt5-opengl gambas3-gb-qt5-webkit gambas3-gb-report2
  gambas3-gb-scanner gambas3-gb-sdl2 gambas3-gb-sdl2-audio gambas3-gb-settings gambas3-gb-signal gambas3-gb-term gambas3-gb-term-form
  gambas3-gb-util gambas3-gb-util-web gambas3-gb-vb gambas3-gb-web gambas3-gb-web-feed gambas3-gb-web-form gambas3-gb-xml gambas3-gb-xml-html
  gambas3-gb-xml-rpc gambas3-gb-xml-xslt gambas3-ide gambas3-script libalure1 libdumb1 libglew2.1 libgmime-3.0-0 libgsl23 libgslcblas0 libimlib2
  libodbc1 libpq5 librpm8 librpmbuild8 librpmio8 librpmsign8 libsdl2-image-2.0-0 libsdl2-mixer-2.0-0 libsdl2-ttf-2.0-0 rpm rpm-common rpm2cpio
The compiling instructions are:
After you installed gambas 3, just checkout and compile xt7 that way:
git clone https://github.com/kokoko3k/xt7-player-mpv.git
cd xt7-player-mpv/
/path/to/gambas/binaries/gbc3 -e -a -g -t -p -m
/path/to/gambas/binaries/gba3
./xt7-player-mpv.gambas
But I don't seem to find that path to /gambas/binaries.
Using sudo find / -type d -name "gambas" 2>/dev/null nothing is found.
This is in Kubuntu 20.04.
cipricus
  • 4,066
  • 47
  • 106
According to package search you need to install gambas3-ide to have /usr/bin/gambas3 in installed to the system.
Full set of the packages is below:
sudo apt-get install gambas3 gambas3-ide gambas3-dev gambas3-gb-libxml
Also you can simply omit /path/to/gambas/binaries/ as all the needed Gambas binaries are installed to /usr/bin/ which is in $PATH variable:
cd xt7-player-mpv/
gba3
N0rbert
  • 103,263
