How to get a charging alert in Ubuntu? I am using a laptop. At the time of using the laptop suddenly goes to shut down because ubuntu not giving the low battery alert.
So pls help me!
Ubuntu by default gives warning messages when the battery is running low. That it doesn't strongly suggest that your battery is starting to fail. A degraded battery looses capacity, and may suddenly loose power, rather than gradually.
You may be helped temporarily by setting the warning levels higher. See this answer to learn how this could be configured.
Adapting the thresholds may trigger warnings earlier, and allow you to be warned in time. Still, in practice, these warnings may, if they appear, appear very soon if your battery is already in a very bad shape. The only fundamental solution then will be to install a new battery pack. You will be good then for at least another three years.
vanadium
  • 97,564
