I'm using Ubuntu 20.04 server edition.
When I run
sudo apt install aptitude
I get the below prompts
Configuration file '/etc/systemd/resolved.conf'
 ==> Modified (by you or by a script) since installation.
 ==> Package distributor has shipped an updated version.
   What would you like to do about it ?  Your options are:
    Y or I  : install the package maintainer's version
    N or O  : keep your currently-installed version
      D     : show the differences between the versions
      Z     : start a shell to examine the situation
 The default action is to keep your current version.
Can I avoid all the prompts and just default to package maintainer's version without being asked?
I will get two kinds of prompts. The command line one as you see above, and the one with slightly more GUI with the pink background asking similar question.
I just want to install with just the package maintainer's version regardless.
Kim Stacks
  • 1,076
If you automate answering to questions in apt, you do that for all prompts at once. It is not possible to selectively disable prompts. See this answer: -y or --yes or --assume-yes will automatically answer -y to all prompts.
vanadium
  • 97,564
