If I shutdown my PC, then remove the connection to the socket and boot it again, the CPU runs at a minimum possible 480MHz. But if I then reboot it again, this time, without removing the socket, the frequency is normal. If you haven't understood yet:
  1. Shut my PC.
  2. Remove the socket connection.
  3. Reboot after a while.
Result: Frequency of 480MHz(which is the minimum possible) and very slow running and booting.
  1. Shut down the PC.
  2. Don't remove the socket.
  3. Reboot
Result: The frequency is back to normal.
Note that I have a laptop with a battery that doesn't work which needs to be constantly plugged in so that I can do my work.
OS: Ubuntu 16.04, 64 bit.
CPU: Intel(R) Celeron(R) CPU N3050 @ 1.6GHz
Product : Inspiron 14-3452 (06AC)
Max frequency: 2160MHz
Min frequency: 480MHz
Additional info:
Normal boot:
/sys/devices/system/cpu/cpu0/cpufreq/scaling_driver:intel_pstate
/sys/devices/system/cpu/cpu1/cpufreq/scaling_driver:intel_pstate
/sys/devices/system/cpu/cpu0/cpufreq/scaling_governor:powersave
/sys/devices/system/cpu/cpu1/cpufreq/scaling_governor:powersave
/sys/devices/system/cpu/intel_pstate/max_perf_pct:100
/sys/devices/system/cpu/intel_pstate/min_perf_pct:22
/sys/devices/system/cpu/intel_pstate/no_turbo:0
/sys/devices/system/cpu/intel_pstate/num_pstates:22
/sys/devices/system/cpu/intel_pstate/status:active
/sys/devices/system/cpu/intel_pstate/turbo_pct:33
Slow boot(480MHz):
Doug Smythies
  • 16,146
Shambhav
  • 111
