17
I'm using Ubuntu 20.10 and I'm trying to get the latest signature-key and when I do that I get these lines:
root@kubernetes-worker:/home/jonteyh# curl https://packages.cloud.google.com/apt/doc/apt-key.gpg | apt-key add -
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100  2537  100  2537    0     0  14016      0 --:--:-- --:--:-- --:--:-- 14094
Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
OK
I get a warning message here that apt-key is deprecated. How do I solve this?
Is there some way I should remove the file trusted.gpg.d or edit it?
Zanna
  • 72,312
Jonte YH
  • 2,113
It looks like apt-key is deprecated from @Terrance. Read this link https://www.linuxuprising.com/2021/01/apt-key-is-deprecated-how-to-add.html
In that link it states that Debian will be ending apt-key as of April 2022. For now apt-key still works as shown in the output in the question where it stated OK which means that the key was imported.
In the future it is recommended to do the signed-by with the repositories that you are adding.
All of this answer is from the link reworded.
First, download the key in question:
For ASCII type keys do it in this form:
wget -O- <https://example.com/key/repo-key.gpg> | gpg --dearmor | sudo tee /usr/share/keyrings/<myrepository>-archive-keyring.gpg
or
curl <https://example.com/key/repo-key.gpg> | gpg --dearmor > /usr/share/keyrings/<myrepository>-archive-keyring.gpg
For non-ASCII type keys do it in this form:
wget -O- <https://example.com/key/repo-key.gpg> | sudo tee /usr/share/keyrings/<myrepository-archive-keyring.gpg>
Or you can get your keys from a keyserver like so:
sudo gpg --no-default-keyring --keyring /usr/share/keyrings/<myrepository>-archive-keyring.gpg --keyserver <hkp://keyserver.ubuntu.com:80> --recv-keys <fingerprint>
All keys will be stored in /usr/share/keyrings/ folder. You can use those keys when you add your repo with the signed-by option to your sources.list file:
deb [signed-by=/usr/share/keyrings/<myrepository>-archive-keyring.gpg] <https://repository.example.com/debian/ stable main>
Or you can add the arch=amd64 in the same fashion:
deb [arch=amd64 signed-by=/usr/share/keyrings/<myrepository>-archive-keyring.gpg] <https://repository.example.com/debian/ stable main>
If this is helpful give thanks to @Terrance
Jonte YH
  • 2,113
