A while back I installed updates via the GUI updater, and got an error, something similar to linux-firmware post-install script failure. Honestly, I was just happy that the box still booted normally after that, so I let it go. But now I was installing a deb package I downloaded from the terminal, and I saw the errors relating to linux-firmware installation again.
I saw this in the log:
dpkg: dependency problems prevent configuration of linux-image-generic:
linux-image-generic depends on linux-firmware; however:
Package linux-firmware is not configured yet.
and I found a post here to try sudo dpkg --configure -a, but the errors are the same.
Here is the entire log for the above command:
Setting up initramfs-tools (0.136ubuntu6.4) ...
update-initramfs: deferring update (trigger activated)
Setting up linux-firmware (1.187.10) ...
update-initramfs: Generating /boot/initrd.img-5.4.0-66-generic
I: The initramfs will attempt to resume from /dev/dm-1
I: (/dev/mapper/ubuntu--vg-swap_1)
I: Set the RESUME variable to override this.
Error 24 : Write error : cannot write compressed block
E: mkinitramfs failure cpio 141 lz4 -9 -l 24
update-initramfs: failed for /boot/initrd.img-5.4.0-66-generic with 1.
dpkg: error processing package linux-firmware (--configure):
installed linux-firmware package post-installation script subprocess returned error exit status 1
Setting up linux-image-5.4.0-67-generic (5.4.0-67.75) ...
I: /boot/initrd.img.old is now a symlink to initrd.img-5.4.0-67-generic
Setting up linux-image-5.4.0-70-generic (5.4.0-70.78) ...
I: /boot/initrd.img is now a symlink to initrd.img-5.4.0-70-generic
dpkg: error processing package linux-image-generic (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of linux-generic:
linux-generic depends on linux-image-generic (= 5.4.0.70.73); however:
Package linux-image-generic is not configured yet.
dpkg: error processing package linux-generic (--configure):
Processing triggers for initramfs-tools (0.136ubuntu6.4) ...
dpkg: error processing package initramfs-tools (--configure):
installed initramfs-tools package post-installation script subprocess returned error exit status 1
Processing triggers for linux-image-5.4.0-67-generic (5.4.0-67.75) ...
/etc/kernel/postinst.d/dkms:
- dkms: running auto installation service for kernel 5.4.0-67-generic
...done.
/etc/kernel/postinst.d/initramfs-tools:
update-initramfs: Generating /boot/initrd.img-5.4.0-67-generic
update-initramfs: failed for /boot/initrd.img-5.4.0-67-generic with 1.
run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return code 1
dpkg: error processing package linux-image-5.4.0-67-generic (--configure):
installed linux-image-5.4.0-67-generic package post-installation script subprocess returned error exit status 1
Processing triggers for linux-image-5.4.0-70-generic (5.4.0-70.78) ...
- dkms: running auto installation service for kernel 5.4.0-70-generic
...done.
update-initramfs: Generating /boot/initrd.img-5.4.0-70-generic
update-initramfs: failed for /boot/initrd.img-5.4.0-70-generic with 1.
dpkg: error processing package linux-image-5.4.0-70-generic (--configure):
installed linux-image-5.4.0-70-generic package post-installation script subprocess returned error exit status 1
linux-firmware
linux-image-generic
linux-generic
initramfs-tools
So the issue I guess is with mkinitramfs
I'm running ubuntu on a Dell Precision 5540, with FDE set up following this guide https://help.ubuntu.com/community/Full_Disk_Encryption_Howto_2019 but I don't know if that has anything to do with it.
It's kind of scary seeing issues with firmware configuration, so I'd like to solve it so it doesn't lead to bigger issues in the future.
