I'm trying to install nodejs, however I get the follow error message:
The following packages have unmet dependencies: nodejs : Depends: python-minimal but it is not installable E: Unable to correct problems, you have held broken packages.
Then when trying to install python-minimal it fails, and says python2-minimal replaces. Python2-minimal is already the newest version
sudo apt-get -f install
Returns with
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
The command:
dpkg --get-selections | grep hold
Does not list any output.
Any suggestions?
sudo apt update output
Hit:1 http://azure.archive.ubuntu.com/ubuntu focal InRelease
Hit:2 http://azure.archive.ubuntu.com/ubuntu focal-updates InRelease
Get:3 http://azure.archive.ubuntu.com/ubuntu focal-backports InRelease [101 kB]
Hit:4 http://security.ubuntu.com/ubuntu focal-security InRelease
Hit:5 https://deb.nodesource.com/node_14.x bionic InRelease
Fetched 101 kB in 0s (254 kB/s)
Reading package lists... Done
Building dependency tree
All packages are up to date.
sudo apt upgrade output
Calculating upgrade... Done
Full sudo apt-get install nodejs output
NPC
This is old, but I just ran into this upgrading an old server. There is a nodejs source that needs to be updated at /etc/apt/sources.list.d/nodesource.list. Change the node version number and the release name. For example, mine had https://deb.nodesource.com/node_10.x bionic InRelease so I updated it to https://deb.nodesource.com/node_18.x focal InRelease. Then run apt update and apt install nodejs.
andyrue
  • 101
