I'd like to install Ubuntu on a laptop that I use for work. The only thing stopping me is that I have a piece of (apparently) 32-bit software that I need for my work. According to the system requirements, it requires a 32-bit version of Linux to run, but I figured that getting it to run on a 64-bit system would be less of a hassle than installing a 32-bit system altogether. Perhaps I was wrong.
When I click on the executable, nothing happens. Trying to run it in the terminal returned the following message:
error while loading shared libraries: libX11.so.6: cannot open shared object file: No such file or directory
When I tried to install the library mentioned above, I got this message: E: Unable to locate package libX11.so.6 E: Couldn't find any package by glob 'libX11.so.6' E: Couldn't find any package by regex 'libX11.so.6'
I've already made sure that Multiarch support is active.
Is there any way to get it to run? Otherwise, is it worth seeking out and installing a 32-bit version of Ubuntu?
Thanks in advance and please go easy on me; I'm a total noob when it comes to Linux :)
ratek
You have to install the 32-bit package with mentioned library by using commands below:
sudo dpkg --add-architecture i386
sudo apt-get update
sudo apt-get install libx11-6:i386
and then try to launch the application. If issue persists with another library - repeat the search process again and install more libraries.
N0rbert
  • 103,263
