Almost a duplicate question of this one, however, the answer in that post does not solve the environmental issue with at command.
Problem description: I want to run my shell scripts with at command as a scheduled job. All my shell scripts run smoothly in a normal terminal in both Ubuntu 10.04 and 20.04 (3 different systems). I get all my results as expected. However, soon as I run my shell script with at, it does not run at all. Here are 3 cases to demonstrate that at works for simple operation and fails complex operation.
case 1
at works with simple script. Following is everything my shell script1.sh:
echo $(date) > ~/Desktop/time.txt
running at now + 1 minutes -f ~/script1.sh, it saves time into time.txt file. Great, it means that my at functions well.
case 2
at fails a simple script. Following is everything my shell script2.sh:
pycharm.sh
running at now + 1 minutes -f ~/script2.sh, it saves time into time.txt file, but the Pycharm was never opened. However, if I run sh script2.sh without using at, everything worked out perfectly, I get the time in time.txt file, and Pycharm opens normally. I think it simply means that at did not get all the variables in an existing terminal environment. Once I add export DISPLAY=:1 to script2.sh as
export DISPLAY=:1
pycharm.sh
then at now + 1 minutes -f ~/script2.sh would function correctly.
case 3
I need to run the following shell script with at as a scheduled job, script3.sh:
gjs -numberofsplits 50 -clusterplatform condor -condorscript condor.script main.mac  > ./output0.txt 2>&1
condor_submit main.submit  > ./output1.txt 2>&1
Please note that all these scripts runs normally in a terminal with sh script.sh, however, running the script with at now + 1 minutes -f ~/script3.sh, it throws an error saved in output0.txt file, it says
gjs: error while loading shared libraries: libG4global.so: cannot open shared object file: No such file or directory
I also tried to use the absolute path of gjs and condor_submit in script3.sh like
/home/albert/Products9/Gate/Gate-9.0-install/bin/gjs -numberofsplits 50 -clusterplatform condor -condorscript condor.script main.mac  > ./output0.txt 2>&1
/usr/bin/condor_submit  > ./output1.txt 2>&1
but it throws the same error.
solutions already tried
By far, I think the problem is well described. I think the cause of this problem is that at command does not have access to all the environment variables as in a normal terminal.
Here are the solutions I have tried posted here, hoping to get all environment variables exposed to at by adding
source $HOME/.profile
or
source $HOME/.bashrc
to the beginning of shell script. However, it does not solve or alleviate the problem at all.
asking for help
May I ask for help from you, the expert in this field, to solve this problem. As this problem may also trouble many other users. Thanks a lot.
One of the reasons is because the at command scheduler is not set to run on a GUI display by default. It should work if you add export DISPLAY=:0 to myscrpit.sh above the line pycharm.py. You can check the DISPLAY variable by typing echo $DISPLAY in a terminal window.
The other reason is the environment variables. The $PATH variable in cron jobs may not contain all the paths where the executables are. There may also be library files.
You can check the path for the executables by typing which <excutable> (e.g. which gjs). For the library directory the varible is $LD_LIBRARY_PATH and to see where the libraries it uses, it's ldd $(which gjs).
Then add export PATH=$PATH:<exepath> and export LD_LIBRARY_PATH=<libpath> to your at scripts.
Aenfa
  • 418
