-1
I have recently installed Lubuntu on my acer aspire 4720z and wanted to switch back to windows but the main problem is that i cannot get the iso over the USB by rufus( as it is not recognising my pendrive, i have installed rufus-3.13.exe from the rufus website and ran it from the Lx terminal by the command - wine rufus-3.13.exe but it is not recognizing my USB)
I tried to write my USB via an app ( i think it is disk) but when i start my system and tried to USB boot via the pendrive, it says that there is no operating system. PLZ HELP ME OUT. I am trying to install win 8.1 or 10 or 7 but plz get me out of Lubuntu............PLZZZZZZZZ
while I'm not sure if this would works, but might as well give it a try.
  1. plug in your USB and run disks.
  2. click on "format disk" and choose "MSDOS" in partitioning.
  3. click on create a new partition and choose NTFS system.
  4. mount window 10 ISO and copy all the files to your USB.
you should able to boot from the USB and install window 10.
Installing Windows 10 without USB using Ubuntu GRUB
  • Backup the Target drive.
  • Create a 6GB NTFS partition on the hard drive and extract the Windows ISO to it.
  • Create a 20GB, or larger, NTFS partition on the hard drive for the Windows Installation.
  • Open Disks, (Gnome-Disks), and note Device, (/dev/sdx), and UUID of the Windows ISO extract partition.
  • For msdos partition table, copy the following menuentry to /etc/grub.d/40-custom/*:
menuentry 'Windows Recovery Environment (on /dev/sda4)' --class windows --class os $menuentry_id_option 'osprober-chain-592C85254E2CD0B7' {
    insmod part_msdos
    insmod ntfs
    set root='hd0,msdos4'
    if [ x$feature_platform_search_hint = xy ]; then
      search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos4 --hint-efi=hd0,msdos4 --hint-baremetal=ahci0,msdos4  592C85254E2CD0B7
    else
      search --no-floppy --fs-uuid --set=root 592C85254E2CD0B7
    fi
    parttool ${root} hidden-
    drivemap -s (hd0) ${root}
    chainloader +1
    ntldr /bootmgr
  • Edit menuentry, changing sda4 to sdax, msdos4 to msdosx (4 places), and 592C85254E2CD0B7 to UUID, (3 places), to suit step 4 above.
  • Run sudo update grub confirm that ntldr /bootmgr appears in grub.cfg.
  • Boot the computer into the newly created Windows menuentry and install Windows into it's new partition.
  • Reinstall Ubuntu if desired, the GRUB bootloader will have been replaced with the Windows bootloader.
*For gpt partition table, copy the following menuentry to /etc/grub.d/40-custom/:
menuentry 'Windows Recovery Environment (on /dev/sdc1)' --class windows --class os $menuentry_id_option 'osprober-chain-5642BC722509341F' {
    insmod part_gpt
    insmod ntfs
    set root='hd0,gpt1'
      search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt1 --hint-efi=hd0,gpt1 --hint-baremetal=ahci0,gpt1  5642BC722509341F
    else
      search --no-floppy --fs-uuid --set=root 5642BC722509341F
    fi
    chainloader +1
    ntldr /bootmgr
Boot selecting Windows from the GRUB menu and follow the instructions.
C.S.Cameron
  • 20,530
  • 78
  • 125
