Since the upgrade to the 5.10.-oem kernel my USB Webcam/Microphone no longer works. Also, the command "lsusb" simply seems to hang and never returns. Everything was still working with the 5.6-generic kernels. Is this a known problem? I could not find any reported issues in this regard.
I would like to switch back to the latest 5.6-generic kernel, what is the safest way to do re-install older kernels without breaking my setup?
Current Kernel is 5.10.0-1019-oem #20-Ubuntu SMP. lsb_release -a No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu 20.04.2 LTS Release: 20.04 Codename: focal
Fant
  • 13
See launchpad bug reports 1918670 1920032
Reboot computer and press ESC key prior to Ubuntu spinner to open the grub menu
Select Advanced options from grub menu to show list of available kernels
Select known working kernel (in my case it was 5.10.0-1016-oem)
After computer finishes booting up open synaptic package manager
sudo apt install synaptic (if not already installed)
Under Sections heading select Kernels and modules and sort for your installed kernels
Select the 5.10.0-1019-oem kernel images to be deleted
select your preferred kernel 5.6? for reinstallation
Select Apply changes
After closing out of synaptic, for good measure I updated grub just to make sure things looked right before rebooting the computer
sudo update-grub
reboot
