For a longtime I try to get Imagemagick running on my Ubuntu 18.04. After a alot of searching and reading I am stuck now installing libheif-dev. It seems there is an easy solution for 20.04 LTS:
https://github.com/libvips/libvips/issues/1511
But on 18.04 LTS I am stuck. Can somebody help me how to install libheif-dev?
Te error I get is:
    make[1]: Entering directory '/home/m0ps/Desktop/video2/BSgen/ImageMagick-7.0.11-4'
  CCLD     utilities/magick
MagickCore/.libs/libMagickCore-7.Q16HDRI.so: undefined reference to `heif_image_set_raw_color_profile'
MagickCore/.libs/libMagickCore-7.Q16HDRI.so: undefined reference to `heif_have_decoder_for_format'
MagickCore/.libs/libMagickCore-7.Q16HDRI.so: undefined reference to `heif_context_add_exif_metadata'
MagickCore/.libs/libMagickCore-7.Q16HDRI.so: undefined reference to `heif_image_handle_get_luma_bits_per_pixel'
MagickCore/.libs/libMagickCore-7.Q16HDRI.so: undefined reference to `heif_context_add_XMP_metadata'
MagickCore/.libs/libMagickCore-7.Q16HDRI.so: undefined reference to `heif_image_handle_get_raw_color_profile_size'
MagickCore/.libs/libMagickCore-7.Q16HDRI.so: undefined reference to `heif_image_handle_get_raw_color_profile'
MagickCore/.libs/libMagickCore-7.Q16HDRI.so: undefined reference to `heif_have_encoder_for_format'
MagickCore/.libs/libMagickCore-7.Q16HDRI.so: undefined reference to `heif_context_read_from_memory_without_copy'
MagickCore/.libs/libMagickCore-7.Q16HDRI.so: undefined reference to `heif_has_compatible_brand'
collect2: error: ld returned 1 exit status
Makefile:8043: recipe for target 'utilities/magick' failed
make[1]: *** [utilities/magick] Error 1
make[1]: Leaving directory '/home/m0ps/Desktop/video2/BSgen/ImageMagick-7.0.11-4'
Makefile:6120: recipe for target 'all' failed
make: *** [all] Error 2
I installed libheif as described here: Problems with compiling ImageMagick with heic
libheif is installed but with libheif there is a problem:
    (base) m0ps@m0ps:/usr/local/lib$ pkg-config libheif --modversion
1.11.0
(base) m0ps@m0ps:/usr/local/lib$ pkg-config libheif-dev --modversion
Package libheif-dev was not found in the pkg-config search path.
Perhaps you should add the directory containing `libheif-dev.pc'
to the PKG_CONFIG_PATH environment variable
No package 'libheif-dev' found
I was searching for 'libheif-dev.pc' but did not find in on my machine
Mips
