I am a total beginner with linux and I'm having a hard time making my wifi work :(
upon reading forums, it said enter some commands in the terminal and I got this:
'''02:00.0 Network controller: Intel Corporation Centrino Wireless-N 1000 [Condor Peak]
DeviceName: Intel(R) Wi-Fi Link 1000
Subsystem: Intel Corporation Centrino Wireless-N 1000 BGN
Flags: bus master, fast devsel, latency 0, IRQ 29
Memory at d5400000 (64-bit, non-prefetchable) [size=8K]
Capabilities: <access denied>
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi'''
from there I don't know where to go or what to do.
I even don't know how to install packages via terminal.
Thank you!
Charles Green
  • 21,859
There is a small confusion at the Intel wireless support page, and you may have the wrong driver for your system.
To resolve this, you will need to download the correct driver form Intel, unpack the compressed files, and copy one specific file to a system directory, and then reboot your computer.
First, open a terminal - press CtrlAltt
Now we will make a folder that we can do the work in, and change to that directory. To do this, enter the following commands.
mkdir wifistuff
cd wifistuff
Now download the correct driver:
wget https://wireless.wiki.kernel.org/_media/en/users/drivers/iwlwifi-1000-ucode-39.31.5.1.tgz
And uncompress the files
tar -xvzf iwlwifi-1000-ucode-39.31.5.1.tgz
Handy hit here: Type tar -xvzf iwl and then press tab
Not change to a directory that was created by the uncompression:
cd iwlwifi-1000-ucode-39.31.5.1
Copy the microcode to the correct system directory. First, make a backup of the file that is already there.
sudo cp /lib/firmware/iwlwifi-1000-5.ucode{,.bak}
sudo cp iwlwifi-1000-5.ucode /lib/firmware/
Please note that the sudo part of this command will prompt you to enter your password.
Finally
reboot
I have largely cribbed this answer from Intel® Centrino® Wireless-N 1000 - Wifi connection is very slow - how do I configure or fix it?
Charles Green
  • 21,859
