For a solution based on an official package: make sure that you have "Universe" enabled in your repositories:
sudo add-apt-repository universe
and that you're using the GNOME desktop or a derivative.
Search Synaptic (or via apt) for the package:
gnome-shell-extension-multi-monitors
Install it, along with the GNOME tweak tool (package "gnome-tweaks", not "gnome-tweak-tool" - the latter is to access some additional settings):
sudo apt-get install gnome-shell-extension-multi-monitors gnome-tweaks
You’ll have to log out and back in (sometimes just reboot your system). After that, search for the Tweak Tool in GNOME menu and launch it. Select "Extensions" on the left-hand side, and scroll till you see multi-monitors-add-on. Activate the slider.
You should see a dual monitor symbol on your taskbar. Click it and select "Preferences". This prefs page will let you tweak all sorts of options... including "Show panel on additional monitors", which is the setting that you are looking for.
