I made a hoorible mistake because I removed pyth 2.7 of my ubuntu machine 18.04 as I wanted to keep only python3 but unfortunately there were some componenents who were installed using pip from the python 2.7 ( ansible for instance).
Now when I try to reinstall python I have the error below :
:~$ sudo apt install python
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: python : PreDepends: python-minimal (= 2.7.12-1~16.04) but it is not going to be installed Depends: python2.7 (>= 2.7.12-1~) but it is not going to be installed E: Unable to correct problems, you have held broken packages.
When I check for residual config I see this :
:~$ apt list | grep residual-config
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
ansible/xenial-updates,xenial-updates,xenial-security,xenial-security 2.0.0.2-2ubuntu1.3 all [residual-config] aspell-en/xenial,xenial 7.1-0-1.1 all [residual-config] docker/xenial,now 1.5-1 amd64 [residual-config] docker.io/xenial-updates 18.09.7-0ubuntu1~16.04.7 amd64 [residual-config] initscripts/xenial,now 2.88dsf-59.3ubuntu2 amd64 [residual-config] insserv/xenial,now 1.14.0-5ubuntu3 amd64 [residual-config] libgdbm3/xenial,now 1.8.3-13.1 amd64 [residual-config] libiscsi2/xenial,now 1.12.0-2 amd64 [residual-config] libjson-c2/xenial-updates,xenial-security 0.11-4ubuntu2.6 amd64 [residual-config] libperl5.22/xenial-updates,xenial-security 5.22.1-9ubuntu0.9 amd64 [residual-config] libpython3.5-minimal/xenial-updates,xenial-security 3.5.2-2ubuntu0~16.04.13 amd64 [residual-config] libserf-1-1/xenial,now 1.3.8-1 amd64 [residual-config] libtxc-dxtn-s2tc0/xenial,now 0~git20131104-1.1 amd64 [residual-config] libunistring0/xenial,now 0.9.3-5.2ubuntu1 amd64 [residual-config] libustr-1.0-1/xenial,now 1.0.4-5 amd64 [residual-config] libv8-3.14.5/xenial,now 3.14.5.8-5ubuntu2 amd64 [residual-config] libxml-sax-perl/xenial,xenial,now 0.99+dfsg-2ubuntu1 all [residual-config] linux-image-4.4.0-112-generic/xenial-updates,xenial-security,now 4.4.0-112.135 amd64 [residual-config] linux-image-4.4.0-124-generic/xenial-updates,xenial-security,now 4.4.0-124.148 amd64 [residual-config] linux-image-4.4.0-148-generic/xenial-updates,xenial-security,now 4.4.0-148.174 amd64 [residual-config] linux-image-4.4.0-93-generic/xenial-updates,xenial-security,now 4.4.0-93.116 amd64 [residual-config] linux-image-extra-4.4.0-112-generic/xenial-updates,xenial-security,now 4.4.0-112.135 amd64 [residual-config] linux-image-extra-4.4.0-124-generic/xenial-updates,xenial-security,now 4.4.0-124.148 amd64 [residual-config] linux-image-extra-4.4.0-93-generic/xenial-updates,xenial-security,now 4.4.0-93.116 amd64 [residual-config] linux-modules-4.4.0-148-generic/xenial-updates,xenial-security,now 4.4.0-148.174 amd64 [residual-config] linux-modules-extra-4.4.0-148-generic/xenial-updates,xenial-security,now 4.4.0-148.174 amd64 [residual-config] lua-lpeg/xenial-updates 0.12.2-1ubuntu1 amd64 [residual-config] lxc-common/xenial-updates,now 2.0.11-0ubuntu1~16.04.3 amd64 [residual-config] mariadb-client-10.0/xenial-updates,xenial-security,now 10.0.38-0ubuntu0.16.04.1 amd64 [residual-config] mariadb-common/xenial-updates,xenial-updates,xenial-security,xenial-security,now 10.0.38-0ubuntu0.16.04.1 all [residual-config] monitoring-plugins-basic/xenial,now 2.1.2-2ubuntu2 amd64 [residual-config] mysql-server-5.7/xenial-updates,xenial-security 5.7.33-0ubuntu0.16.04.1 amd64 [residual-config] nginx-common/xenial-updates,xenial-updates,xenial-security,xenial-security 1.10.3-0ubuntu0.16.04.5 all [residual-config] ntp/xenial-updates,xenial-security 1:4.2.8p4+dfsg-3ubuntu5.10 amd64 [residual-config] ntpdate/xenial-updates,xenial-security 1:4.2.8p4+dfsg-3ubuntu5.10 amd64 [residual-config] openjdk-8-jre-headless/xenial-updates,xenial-security 8u282-b08-0ubuntu1~16.04 amd64 [residual-config] php-pear/bionic,bionic 1:1.10.8+submodules+notgz-1+ubuntu18.04.1+deb.sury.org+1 all [residual-config] php7.0-curl/bionic 7.0.33-29+ubuntu18.04.1+deb.sury.org+1 amd64 [residual-config] php7.0-gd/bionic 7.0.33-29+ubuntu18.04.1+deb.sury.org+1 amd64 [residual-config] php7.0-ldap/bionic 7.0.33-29+ubuntu18.04.1+deb.sury.org+1 amd64 [residual-config] php7.0-mysql/bionic 7.0.33-29+ubuntu18.04.1+deb.sury.org+1 amd64 [residual-config] php7.0-xmlrpc/bionic 7.0.33-29+ubuntu18.04.1+deb.sury.org+1 amd64 [residual-config] python/xenial-updates 2.7.12-1~16.04 amd64 [residual-config] python3.5-minimal/xenial-updates,xenial-security 3.5.2-2ubuntu0~16.04.13 amd64 [residual-config] resolvconf/xenial-updates,xenial-updates 1.78ubuntu7 all [residual-config] subversion/xenial-updates,xenial-security 1.9.3-2ubuntu1.3 amd64 [residual-config] sysv-rc/xenial,xenial,now 2.88dsf-59.3ubuntu2 all [residual-config] xterm/xenial-updates,xenial-security 322-1ubuntu1.2 amd64 [residual-config]
And when I check for held packages using dpkg nothing appears :
~$ dpkg --get-selections | grep hold
My OS version is :
~$ cat /etc/os-release
NAME="Ubuntu"
VERSION="18.04.3 LTS (Bionic Beaver)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 18.04.3 LTS"
I know that I've caused damage and I learnt it the hard way,Now what is the appropriate way to reinstall python 2.7.12 ?
Any help, hint or advice will be more than appreciated.
I uugraded the whole OS now everything is in order thank you for your help and time
