I used sudo mkfs.vfat /dev/sdb to format a flash drive (I didn't notice /sd*) but accidentally my Seagate external hard disk (/dev/sdb) started being formatted and immediately after few seconds I cancelled that command. I was still able to use the hard disk as it was already mounted to my Ubuntu machine, but when I unmounted it and tried to access it Ubuntu didn't detect it anymore.
Results of sudo mount /dev/sdb /media/backup:
mount: /media/backup: wrong fs type, bad option, bad superblock on /dev/sdb, missing codepage or helper program, or other error.
Results of sudo fdisk -l # pasting the last few paragraphs:
Disk /dev/sda: 931.53 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: ST1000DM003-1ER1
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: dos
Disk identifier: 0x7f7a3175
Device Boot Start End Sectors Size Id Type /dev/sda1 * 2048 199999487 199997440 95.4G 83 Linux /dev/sda2 200001534 1953523711 1753522178 836.1G 5 Extended /dev/sda5 200001536 1953523711 1753522176 836.1G 83 Linux
Partition 2 does not start on physical sector boundary. Disk /dev/sdb: 3.65 TiB, 4000787029504 bytes, 7814037167 sectors Disk model: BUP Portable
Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Results of df -h:
Filesystem      Size  Used Avail Use% Mounted on
udev             12G     0   12G   0% /dev
tmpfs           2.4G  1.8M  2.4G   1% /run
/dev/sda1        94G  9.4G   80G  11% /
tmpfs            12G  197M   12G   2% /dev/shm
tlsblkmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs            12G     0   12G   0% /sys/fs/cgroup
/dev/loop0       56M   56M     0 100% /snap/core18/1988
/dev/loop2       32M   32M     0 100% /snap/snapd/11036
/dev/loop1       65M   65M     0 100% /snap/gtk-common-themes/1514
/dev/loop3      219M  219M     0 100% /snap/gnome-3-34-1804/66
/dev/loop5       33M   33M     0 100% /snap/snapd/11107
/dev/loop4       52M   52M     0 100% /snap/snap-store/518
/dev/sda5       823G  716G   65G  92% /home
tmpfs           2.4G   28K  2.4G   1% /run/user/1000
Results of lsblk:
NAME   MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
loop0    7:0    0  55.5M  1 loop /snap/core18/1988
loop1    7:1    0  64.8M  1 loop /snap/gtk-common-themes/1514
loop2    7:2    0  31.1M  1 loop /snap/snapd/11036
loop3    7:3    0   219M  1 loop /snap/gnome-3-34-1804/66
loop4    7:4    0    51M  1 loop /snap/snap-store/518
loop5    7:5    0  32.3M  1 loop /snap/snapd/11107
sda      8:0    0 931.5G  0 disk
├─sda1   8:1    0  95.4G  0 part /
├─sda2   8:2    0     1K  0 part
─sda5    8:5    0 836.1G  0 part /home
sdb      8:16   0   3.7T  0 disk
My PhD career is based on data inside it. Please help to restore my data.
karel
  • 122,292
  • 133
  • 301
  • 332
