I installed 12.04 LTS 64 bits from a USB drive, but I can't seem to boot from the HDD. I have a single partition, with no other OSes. I need to plug in the USB drive for the PC to boot Ubuntu. Is my install OK?
I'm no expert but could it be that you installed the boot loader GRUB on your USB drive? Would explain your problem to me.
When you have booted succesfully, you can check your boot loader location from a Terminal while the USB drive is mounted:
sudo fdisk -l
You will get a output like that:
Disk /dev/sda: 500.1 GB, 500107862016 bytes
255 Köpfe, 63 Sektoren/Spur, 60801 Zylinder, zusammen 976773168 Sektoren
Einheiten = Sektoren von 1 × 512 = 512 Bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0xe3746708
Gerät boot. Anfang Ende Blöcke Id System
/dev/sda1 * 2048 206847 102400 7 HPFS/NTFS/exFAT
/dev/sda2 206848 163839999 81816576 7 HPFS/NTFS/exFAT
/dev/sda3 163840000 794142719 315151360 7 HPFS/NTFS/exFAT
/dev/sda4 794144766 976771071 91313153 5 Erweiterte
/dev/sda5 968773632 976771071 3998720 82 Linux Swap / Solaris
/dev/sda6 794144768 968773631 87314432 83 Linux
Partitionstabelleneinträge sind nicht in Platten-Reihenfolge
Disk /dev/sdb: 2000.4 GB, 2000398934016 bytes
255 Köpfe, 63 Sektoren/Spur, 243201 Zylinder, zusammen 3907029168 Sektoren
Disk identifier: 0x000c8204
/dev/sdb1 2048 3907026943 1953512448 83 Linux
The * indicates the boot loader location. When it is listed somewhere on your OS HDD, I was wrong.
If I was right, I will post a solution when you commented to my answer. I don't want to talk you into doing the wrong commands and break you installation completely.
- 783
means that your bootloader (GRUB) is installed on this USB disk, but not on your hard disk.
Solution is simply to install GRUB in the MBR of your hard disk. You can do it for example this way:
- Boot your installed Ubuntu system
- Disconnect your USB key
- Open a terminal (Ctrl+Alt+T)
- type
sudo grub-install /dev/sda
Or you can use the Boot-Repair graphical tool.
- 72,312
- 3,785
