So I recently bought a raspberry pi, and I am trying to install ubuntu server 20.04 on it. I can't seem to configure wireless networking. I've tried editing the 50-cloud-init.yaml file and it doesn't seem to work. I've googled my issue and haven't been able to fix it.
50-cloud-init.yaml looks as follows
network:
   ethernets:
       eth0:
           dhcp4: true
           optional: true
       wlan0:
           access-points:
               "newgateway_5GHz":
                  password: "clearfield"
           version: 2
When I run sudo netplan --debug try I get the message /etc/netplan/50-cloud-init.yaml:12:13: Error in network definition: unknown key 'access-points' I've edited the file in many different ways, I've used sudo nano /etc/netplan/50-cloud-init.yaml to edit the file as well as after installing it, as well as opening the partition on the sd card and went to network-config and changed it that way.
I've googled my problem and I've had no, luck any ideas?
From the examples on netplan.io, I would assume your file should look something like this:
network:
    version: 2
    ethernets:
        eth0:
            dhcp4: true
            optional: true
    wifis:
        wlan0:
            access-points:
                "my_ssid":
                    password: "my_password"
            dhcp4: true
            optional: true
3 obvious errors in your file was:
  1. that version: 2 had incorrect indentation,
  2. that you defined your AP under the ethernets section, where it should be under the wifis section, and
  3. that you missed the dhcp4: true statement for your wifi.
In addition, you might need to run these commands:
sudo systemctl enable wpa_supplicant
sudo systemctl start wpa_supplicant
sudo netplan generate
sudo netplan apply
I hope this works out.
Artur Meinild
  • 31,035
