I am getting this error when I am trying to install VirtualBox-6.1. I cannot turn off the secure boot. I am installing Virtual box for I want to use Homestead
Preparing to unpack virtualbox-6.1_6.1.18-142142_Ubuntu_eoan_amd64.deb ...
Unpacking virtualbox-6.1 (6.1.18-142142~Ubuntu~eoan) over (6.1.18-142142~Ubuntu~eoan) ...
Setting up virtualbox-6.1 (6.1.18-142142~Ubuntu~eoan) ...
addgroup: The group `vboxusers' already exists as a system group. Exiting.
vboxdrv.sh: failed: modprobe vboxdrv failed. Please use 'dmesg' to find out why.
There were problems setting up VirtualBox. To re-start the set-up process, run /sbin/vboxconfig as root. If your system is using EFI Secure Boot you may need to sign the kernel modules (vboxdrv, vboxnetflt, vboxnetadp, vboxpci) before you can load them. Please see your Linux system's documentation for more information. Processing triggers for systemd (245.4-4ubuntu3.4) ... Processing triggers for gnome-menus (3.36.0-1ubuntu1) ... Processing triggers for desktop-file-utils (0.24-1ubuntu3) ... Processing triggers for mime-support (3.64ubuntu1) ... Processing triggers for hicolor-icon-theme (0.17-2) ... Processing triggers for shared-mime-info (1.15-1) ...
I have tried the solution by majal. I am using ubuntu 20.04.2
Output of uname -r is 5.8.0-44-generic
Please Help.
Maybe a Kernel issue, First install mainline here
Then downgrade the kernel to 5.4 by: installing it edit sudo vim /etc/default/grub as follow
GRUB_DEFAULT="**gnulinux-5.4.112-0504112-generic-advanced-06ee5ff5-b952-4d40-858f-869172f710ce**"
GRUB_TIMEOUT_STYLE=hidden GRUB_TIMEOUT=10 GRUB_DISTRIBUTOR=lsb_release -i -s 2> /dev/null || echo Debian GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" GRUB_CMDLINE_LINUX=""
Update grub sudo update-grub then sudo reboot After reboot sudo apt remove virtualbox-dkms and then sudo apt install virtualbox-dkms to rebuild for the 5.4 kernel
then sudo modprobe vboxdrv
done!
