I have Laravel project on Ubuntu. Project is placed in /var/www/html/myproj.
I have my local project on Windows and after some changes I want to upload MyController.php on Ubuntu.
From Filezilla I get message: File couldn't be transferred
On Ubuntu file is in:
user1@bpl:/var/www/html/myproj/app/Http/Controllers/Admin$ ls -al
total 76
drwxr-xr-x 2 www-data www-data 4096 Mar 13 12:26 .
drwxrwxr-x 4 www-data www-data 4096 Mar 14 21:21 ..
-rw-r--r-- 1 www-data www-data 1170 Mar 13 12:26 AuthController.php
For uploading I user ftpuser1, this user is added to www-data group:
user1@bpl:/var/www/html/myproj$ getent group www-data
www-data:x:33:user1,ftpuser1
Home directory of ftpuser1 is:
user1@bpl:/var/www/html/myproj$ eval echo ~ftpuser1
/var/www/html/
vsftpd works, there is no problem with ftp deamon, because generally I can upload files via Filezilla, I have problem with upload files into Laravel project into Admin directory
user1@bpl:/var/www/html/myproj$ systemctl status vsftpd
● vsftpd.service - vsftpd FTP server
Loaded: loaded (/lib/systemd/system/vsftpd.service; enabled; vendor preset: e
Active: active (running) since Thu 2021-03-11 18:23:37 UTC; 3 days ago
Main PID: 1073 (vsftpd)
Tasks: 1 (limit: 4915)
CGroup: /system.slice/vsftpd.service
└─1073 /usr/sbin/vsftpd /etc/vsftpd.conf
This is response in Filezilla from server:
Command: PASV
Response: 227 Entering Passive Mode (185,163,47,161,39,70).
Command: STOR AuthController.php
Response: 553 Could not create file.
Error: Critical file transfer error
Status: Retrieving directory listing of "/myproj/app/Http/Controllers/Admin"...
On this website, I've found article who permissions for Laravel files should be set: Laravel files on Ubuntu permissions
and it is described that for file permission should be 644 the same as I have:
Then you set all your directories to 755 and your files to 644... SET file permissions
sudo find /path/to/your/laravel/root/directory -type f -exec chmod 644 {} \;SET directory permissions
sudo find /path/to/your/laravel/root/directory -type d -exec chmod 755 {} \;
but this configuration don't allow upload files using Filezilla and vsftpd
