Previously, I was needed to install homebrew. I opened the terminal and executed the command for it. However, it was taking to long and I was also short on the data limit. So, I interupted the execution in the terminal. When I restarted the system, I got following warning
/home/user/.profile: line 28 /bin/brew: No such file or directory
/home/user/.profile: line 29 /bin/brew: No such file or directory
/home/user/.profile: line 30 /bin/brew: No such file or directory
/home/user/.profile: line 31 /bin/brew: No such file or directory
/home/user/.profile: line 32 /bin/brew: No such file or directory
As a result the session will not be configured correctly.
You should fix the problem as soon as feasible
I don't know how can I fix this. Kindly suggest some.
When I executed grep -i mesg .profile I got nothing.
For grep -i mesg .bash* I got .bash_history:grep -i mesg
The system is running normal as it was before while the warning pop up each time the system is turned on. However, my openweather gnome extension is not working.
EDIT: grep -i brew .profile gives
eval $(/bin/brew shellenv)
grep -i brew .bash*
gives
.bash_history:test -d ~/.linuxbrew && eval $(~/.linuxbrew/bin/brew shellenv)
.bash_history:test -d /home/linuxbrew/.linuxbrew && eval $(/home/linuxbrew/.linuxbrew/bin/brew shellenv)
.bash_history:test -r ~/.profile && echo "eval \$($(brew --prefix)/bin/brew shellenv)" >>~/.profile
.bash_history:test -d ~/.linuxbrew && eval $(~/.linuxbrew/bin/brew shellenasasasasasasav)
.bash_history:/bin/bash -c "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/HEAD/install.sh)"
.bash_history:/bin/bash -c "$(sudo -fsSL https://raw.githubusercontent.com/Homebrew/install/HEAD/install.sh)"
.bash_history:/bin/bash -c "$(sudo wget -fsSL https://raw.githubusercontent.com/Homebrew/install/HEAD/install.sh)"
.bash_history:/bin/bash -c "$(sudo wget https://raw.githubusercontent.com/Homebrew/install/HEAD/install.sh)"
.bash_history:brew instal bf
.bash_history:test -r ~/.bash_profile && echo "eval \$($(brew --prefix)/bin/brew shellenv)" >>~/.bash_profile
.bash_history:echo "eval \$($(brew --prefix)/bin/brew shellenv)" >>~/.profile
.bash_history:/usr/local/bin/brew doctor
.bash_history:sh -c "$(curl -fsSL https://raw.gtihubusercontent.com/linuxbrew/install/master/install.sh)"
.bash_history:sh -c "$(curl -fsSL https://raw.githubusercontent.com/linuxbrew/install/master/install.sh)"
.bash_history:Command 'brew' not found, did you mean:
