Why do the installation of Sagemath fails on Ubuntu? I tried
jaakko@jaakko-Aspire-E1-572:~$ sudo apt install sagemath-common
[sudo] password for jaakko:
Reading package lists... Done
Building dependency tree
The following NEW packages will be installed:
  sagemath-common
0 upgraded, 1 newly installed, 0 to remove and 8 not upgraded.
Need to get 16,2 MB of archives.
After this operation, 205 MB of additional disk space will be used.
Get:1 http://fi.archive.ubuntu.com/ubuntu focal/universe amd64 sagemath-common all 9.0-1ubuntu4 [16,2 MB]
Fetched 16,2 MB in 4s (3 888 kB/s)
Selecting previously unselected package sagemath-common.
(Reading database ... 216481 files and directories currently installed.)
Preparing to unpack .../sagemath-common_9.0-1ubuntu4_all.deb ...
Unpacking sagemath-common (9.0-1ubuntu4) ...
Setting up sagemath-common (9.0-1ubuntu4) ...
/usr/lib/python3/dist-packages/sage/combinat/root_system/branching_rules.py:1753
: SyntaxWarning: "is not" with a literal. Did you mean "!="?
  if len(stypes) is not 2:
/usr/lib/python3/dist-packages/sage/graphs/graph_latex.py:1159: SyntaxWarning: '
str' object is not callable; perhaps you missed a comma?
  raise TypeError('%s option must be a dictionary, not %s' (name, value))
/usr/lib/python3/dist-packages/sage/graphs/graph_latex.py:1168: SyntaxWarning: '
/usr/lib/python3/dist-packages/sage/graphs/graph_latex.py:1175: SyntaxWarning: '
/usr/lib/python3/dist-packages/sage/graphs/graph_latex.py:1182: SyntaxWarning: '
/usr/lib/python3/dist-packages/sage/graphs/graph_latex.py:1189: SyntaxWarning: '
/usr/lib/python3/dist-packages/sage/graphs/graph_latex.py:1196: SyntaxWarning: '
/usr/lib/python3/dist-packages/sage/graphs/graph_latex.py:1203: SyntaxWarning: '
Processing triggers for man-db (2.9.1-1) ...
jaakko@jaakko-Aspire-E1-572:~$ sage
│ SageMath version 9.0, Release Date: 2020-01-01                     │
│ Using Python 3.8.5. Type "help()" for help.                        │
Traceback (most recent call last):
  File "/usr/share/sagemath/bin/sage-ipython", line 12, in <module>
    from sage.repl.interpreter import SageTerminalApp
  File "/usr/lib/python3/dist-packages/sage/repl/interpreter.py", line 105, in <module>
    from sage.repl.preparse import preparse, containing_block
  File "/usr/lib/python3/dist-packages/sage/repl/preparse.py", line 227, in <module>
    from sage.repl.load import load_wrap
  File "/usr/lib/python3/dist-packages/sage/repl/load.py", line 19, in <module>
    from sage.cpython.string import str_to_bytes, bytes_to_str, FS_ENCODING
ModuleNotFoundError: No module named 'sage.cpython.string'
To install Sage Math, enter the command sudo apt install sagemath.
sagemath-common (which you installed) is one of the many dependencies of the whole package. When you install sagemath, it would automatically install all the required dependencies.
See this question for how to install sagemath in 24.04.
It is now recommended to use 9.7 or higher version (https://doc.sagemath.org/html/en/installation/linux.html)
so i found this guide which helped me install and run SageMath in Jupyter
G. Siganos
  • 101
