I followed this guide here: TP-Link AC600 Archer T2U Nano driver for Ubuntu 18.04 since I have the same wifi adapter that was working at that point but was giving me much lower speeds than my windows partition. After rebooting my wifi adapter is not recognized anymore... It shows in lsusb command.
Any suggestions on how to go back to it?
Edit: I tried installing from another repository (https://github.com/gnab/rtl8812au) and this is what I got:
dkms status
8812au, 4.2.3, 5.4.0-66-generic, x86_64: installed (WARNING! Diff between built and installed module!)
Edit: I get this from uninstalling
sudo dkms uninstall 8812au/4.2.3
-------- Uninstall Beginning -------- Module: 8812au Version: 4.2.3 Kernel: 5.4.0-66-generic (x86_64)
Status: Before uninstall, this module version was ACTIVE on this kernel.
8812au.ko:
  • Uninstallation
    • Deleting from: /lib/modules/5.4.0-66-generic/
rmdir: failed to remove '': No such file or directory
  • Original module
    • No original module was found for this module on this kernel.
    • Use the dkms install command to reinstall any previous module version.
depmod...
DKMS: uninstall completed.
dkms status 8812au, 4.2.3, 5.4.0-66-generic, x86_64: built 8812au, 4.2.3, 5.4.0-66-lowlatency, x86_64: installed
sudo dkms remove 8812au/4.2.3 --all
Status: This module version was INACTIVE for this kernel. depmod...
-------- Uninstall Beginning -------- Module: 8812au Version: 4.2.3 Kernel: 5.4.0-66-lowlatency (x86_64)
8812au.ko:
  • Uninstallation
    • Deleting from: /lib/modules/5.4.0-66-lowlatency/updates/dkms/
  • Original module
depmod...
Deleting module version: 4.2.3 completely from the DKMS tree.
Done. stella@IBP10382:~$ dkms status stella@IBP10382:~$
And after reinstalling, the same
stella@IBP10382:~$ sudo apt-get install build-essential dkms
Reading package lists... Done
Building dependency tree
build-essential is already the newest version (12.4ubuntu1).
dkms is already the newest version (2.3-3ubuntu9.7).
The following package was automatically installed and is no longer required:
  linux-hwe-5.4-headers-5.4.0-62
Use 'sudo apt autoremove' to remove it.
0 upgraded, 0 newly installed, 0 to remove and 6 not upgraded.
stella@IBP10382:~$ sudo make dkms_install
make: *** No rule to make target 'dkms_install'.  Stop.
stella@IBP10382:~$ cd rtl8812au/
stella@IBP10382:~/rtl8812au$ sudo make dkms_install
mkdir -p /usr/src/8812au-4.2.3
cp -r * /usr/src/8812au-4.2.3
dkms add -m 8812au -v 4.2.3
Creating symlink /var/lib/dkms/8812au/4.2.3/source -> /usr/src/8812au-4.2.3
DKMS: add completed. dkms build -m 8812au -v 4.2.3
Kernel preparation unnecessary for this kernel. Skipping...
Building module: cleaning build area... 'make' all KVER=5.4.0-66-generic.......... cleaning build area...
DKMS: build completed. dkms install -m 8812au -v 4.2.3
8812au: Running module version sanity check.
Good news! Module version v4.2.3 for 8812au.ko exactly matches what is already found in kernel 5.4.0-66-generic. DKMS will not replace this module. You may override by specifying --force.
depmod...
DKMS: install completed. dkms status 8812au, 4.2.3, 5.4.0-66-generic, x86_64: installed (WARNING! Diff between built and installed module!) stella@IBP10382:~/rtl8812au$ echo 8812au | sudo tee -a /etc/modules 8812au
By the way, the driver it was using previously was this: mt76x0u
Many thanks!
StlCh
