After updating to Ubuntu 10.10 (Gnome), KMyMoney now opens in fullscreen mode by default, and I can't find any option to get out of fullscreen. I've tried pressing F11, and I've taken a pretty good look through the view options, but I can't find any way to turn off fullscreen mode. After a little looking, it seems like KMyMoney's preferences can't be found in gconf-editor, and there doesn't seem to be a command-line switch for turning fullscreen on or off. So I'm at a loss, and any help would be much appreciated, thanks!
Kmymoney is not a gtk/gnome application; it doesn't use gconf. That's the first thing. If you are using compiz, there is a fullscreen shortcut (usually super+f).
You can try that first. If that does not work, then try accessing the menu by pressing alt+f or f10. Some kde applications start in full screen mode under GNOME (I've never found out why, sadly). If all else fails, someone may be able to provide more information than me.
RolandiXor
  • 51,797
