I have installed ubuntu 20.04LTS. My laptop is HP probook 645 g4, amd ryzen7. Intel wireless ac3168NGW is used in this laptop to use wifi. After installing Ubuntu, the 'Additional Drivers' in the Software & update, it is showing that intel corporation: Dual Band Wireless-AC3168NGW [stone peak]-this device is not working. and give me an option to contine using a manually installed driver. I have tried 2 common solutions. The wifi comes and suddenly gets disconnected. After getting disconnected, in the wifi section in the system setting, it is showing that the wifi adapter is not found. and the wifi on-off button is gone away. It's really a pain. I have given the 2 solutions below. These do not work perfectly. if anyone gives me a perfect solution,
my-try-1:
wget https://wireless.wiki.kernel.org/_media/en/users/drivers/iwlwifi-3168-ucode-22.361476.0.tgz
tar xvf iwlwifi-3168-ucode-22.361476.0.tgz
cd iwlwifi-3168-ucode-22.361476.0
sudo cp iwlwifi* /lib/firmware
sudo modprobe -v iwlwifi
my-try-2:
sudo apt update
sudo apt install linux-generic-hwe-20.04
and.. I am not using any dual boot. I have installed ubuntu whole my hard drive. "dmesg | grep iwl" result below.
santo@santo-HP-ProBook-645-G4:~$ dmesg | grep iwl
[    8.185397] iwlwifi 0000:02:00.0: enabling device (0000 -> 0002)
[    8.529421] iwlwifi 0000:02:00.0: loaded firmware version 29.1654887522.0 3168-29.ucode op_mode iwlmvm
[    8.531171] iwlwifi 0000:02:00.0: Direct firmware load for iwl-debug-yoyo.bin failed with error -2
[    9.741272] iwlwifi 0000:02:00.0: Detected Intel(R) Dual Band Wireless AC 3168, REV=0x220
[    9.764147] iwlwifi 0000:02:00.0: base HW address: f4:d1:08:30:92:29
[    9.794546] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[    9.800278] iwlwifi 0000:02:00.0 wlp2s0: renamed from wlan0
[  124.117970] iwlwifi 0000:02:00.0: regular scan timed out
[  124.118166] iwlwifi 0000:02:00.0: Microcode SW error detected.  Restarting 0x2000000.
[  124.118350] iwlwifi 0000:02:00.0: Start IWL Error Log Dump:
[  124.118354] iwlwifi 0000:02:00.0: Status: 0x00000040, count: 6
[  124.118356] iwlwifi 0000:02:00.0: Loaded firmware version: 29.1654887522.0 3168-29.ucode
[  124.118360] iwlwifi 0000:02:00.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
[  124.118362] iwlwifi 0000:02:00.0: 0x00000230 | trm_hw_status0
[  124.118364] iwlwifi 0000:02:00.0: 0x00000000 | trm_hw_status1
[  124.118366] iwlwifi 0000:02:00.0: 0x00043D6C | branchlink2
[  124.118368] iwlwifi 0000:02:00.0: 0x0004AFA2 | interruptlink1
[  124.118370] iwlwifi 0000:02:00.0: 0x000008A0 | interruptlink2
[  124.118372] iwlwifi 0000:02:00.0: 0x00000000 | data1
[  124.118374] iwlwifi 0000:02:00.0: 0x00000080 | data2
[  124.118375] iwlwifi 0000:02:00.0: 0x07030000 | data3
[  124.118377] iwlwifi 0000:02:00.0: 0x63802E09 | beacon time
[  124.118379] iwlwifi 0000:02:00.0: 0xB33781F6 | tsf low
[  124.118381] iwlwifi 0000:02:00.0: 0x00000000 | tsf hi
[  124.118382] iwlwifi 0000:02:00.0: 0x00000000 | time gp1
[  124.118384] iwlwifi 0000:02:00.0: 0x05F0D44C | time gp2
[  124.118386] iwlwifi 0000:02:00.0: 0x00000001 | uCode revision type
[  124.118388] iwlwifi 0000:02:00.0: 0x0000001D | uCode version major
[  124.118389] iwlwifi 0000:02:00.0: 0x62A39462 | uCode version minor
[  124.118391] iwlwifi 0000:02:00.0: 0x00000220 | hw version
[  124.118393] iwlwifi 0000:02:00.0: 0x00C89200 | board version
[  124.118395] iwlwifi 0000:02:00.0: 0x0000001C | hcmd
[  124.118396] iwlwifi 0000:02:00.0: 0x24022002 | isr0
[  124.118398] iwlwifi 0000:02:00.0: 0x00800000 | isr1
[  124.118400] iwlwifi 0000:02:00.0: 0x0000000A | isr2
[  124.118402] iwlwifi 0000:02:00.0: 0x00417CC0 | isr3
[  124.118403] iwlwifi 0000:02:00.0: 0x00000000 | isr4
[  124.118405] iwlwifi 0000:02:00.0: 0x00F1014E | last cmd Id
[  124.118407] iwlwifi 0000:02:00.0: 0x00000000 | wait_event
[  124.118408] iwlwifi 0000:02:00.0: 0x00000080 | l2p_control
[  124.118410] iwlwifi 0000:02:00.0: 0x00010030 | l2p_duration
[  124.118412] iwlwifi 0000:02:00.0: 0x0000003F | l2p_mhvalid
[  124.118414] iwlwifi 0000:02:00.0: 0x000000CE | l2p_addr_match
[  124.118415] iwlwifi 0000:02:00.0: 0x00000007 | lmpm_pmg_sel
[  124.118417] iwlwifi 0000:02:00.0: 0x16070617 | timestamp
[  124.118419] iwlwifi 0000:02:00.0: 0x0034B0C0 | flow_handler
[  124.118530] iwlwifi 0000:02:00.0: Fseq Registers:
[  124.118579] iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_ERROR_CODE
[  124.118624] iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_TOP_INIT_VERSION
[  124.118670] iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_CNVIO_INIT_VERSION
[  124.118717] iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_OTP_VERSION
[  124.118763] iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_TOP_CONTENT_VERSION
[  124.118809] iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_ALIVE_TOKEN
[  124.118855] iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_CNVI_ID
[  124.118902] iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_CNVR_ID
[  124.118948] iwlwifi 0000:02:00.0: 0x00000000 | CNVI_AUX_MISC_CHIP
[  124.118995] iwlwifi 0000:02:00.0: 0x00000000 | CNVR_AUX_MISC_CHIP
[  124.119041] iwlwifi 0000:02:00.0: 0x00000000 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[  124.119086] iwlwifi 0000:02:00.0: 0x00000000 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[  124.119140] iwlwifi 0000:02:00.0: Collecting data: trigger 2 fired.
[  144.592938] iwlwifi 0000:02:00.0: regular scan timed out
[  144.593260] iwlwifi 0000:02:00.0: Microcode SW error detected.  Restarting 0x2000000.
[  144.593493] iwlwifi 0000:02:00.0: Start IWL Error Log Dump:
[  144.593497] iwlwifi 0000:02:00.0: Status: 0x00000040, count: 6
[  144.593501] iwlwifi 0000:02:00.0: Loaded firmware version: 29.1654887522.0 3168-29.ucode
[  144.593505] iwlwifi 0000:02:00.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
[  144.593508] iwlwifi 0000:02:00.0: 0x000002F3 | trm_hw_status0
[  144.593511] iwlwifi 0000:02:00.0: 0x00000000 | trm_hw_status1
[  144.593513] iwlwifi 0000:02:00.0: 0x00043D6C | branchlink2
[  144.593516] iwlwifi 0000:02:00.0: 0x0004AFA2 | interruptlink1
[  144.593519] iwlwifi 0000:02:00.0: 0x000066FC | interruptlink2
[  144.593521] iwlwifi 0000:02:00.0: 0x00000000 | data1
[  144.593524] iwlwifi 0000:02:00.0: 0x00000080 | data2
[  144.593526] iwlwifi 0000:02:00.0: 0x03030000 | data3
[  144.593529] iwlwifi 0000:02:00.0: 0x89005E5D | beacon time
[  144.593531] iwlwifi 0000:02:00.0: 0xB47035A2 | tsf low
[  144.593534] iwlwifi 0000:02:00.0: 0x00000000 | tsf hi
[  144.593536] iwlwifi 0000:02:00.0: 0x00000000 | time gp1
[  144.593538] iwlwifi 0000:02:00.0: 0x0135685A | time gp2
[  144.593541] iwlwifi 0000:02:00.0: 0x00000001 | uCode revision type
[  144.593543] iwlwifi 0000:02:00.0: 0x0000001D | uCode version major
[  144.593546] iwlwifi 0000:02:00.0: 0x62A39462 | uCode version minor
[  144.593548] iwlwifi 0000:02:00.0: 0x00000220 | hw version
[  144.593550] iwlwifi 0000:02:00.0: 0x00C89200 | board version
[  144.593552] iwlwifi 0000:02:00.0: 0x0000001C | hcmd
[  144.593555] iwlwifi 0000:02:00.0: 0x02F62000 | isr0
[  144.593557] iwlwifi 0000:02:00.0: 0x01004000 | isr1
[  144.593559] iwlwifi 0000:02:00.0: 0x0000000A | isr2
[  144.593561] iwlwifi 0000:02:00.0: 0x00417C80 | isr3
[  144.593563] iwlwifi 0000:02:00.0: 0x00000000 | isr4
[  144.593566] iwlwifi 0000:02:00.0: 0x0B80001C | last cmd Id
[  144.593568] iwlwifi 0000:02:00.0: 0x00000000 | wait_event
[  144.593570] iwlwifi 0000:02:00.0: 0x00000080 | l2p_control
[  144.593572] iwlwifi 0000:02:00.0: 0x00001C22 | l2p_duration
[  144.593574] iwlwifi 0000:02:00.0: 0x0000003F | l2p_mhvalid
[  144.593576] iwlwifi 0000:02:00.0: 0x000000CE | l2p_addr_match
[  144.593579] iwlwifi 0000:02:00.0: 0x00000007 | lmpm_pmg_sel
[  144.593581] iwlwifi 0000:02:00.0: 0x16070617 | timestamp
[  144.593583] iwlwifi 0000:02:00.0: 0x0034C8D8 | flow_handler
[  144.593695] iwlwifi 0000:02:00.0: Fseq Registers:
[  144.593741] iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_ERROR_CODE
[  144.593787] iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_TOP_INIT_VERSION
[  144.593833] iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_CNVIO_INIT_VERSION
[  144.593881] iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_OTP_VERSION
[  144.593928] iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_TOP_CONTENT_VERSION
[  144.593974] iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_ALIVE_TOKEN
[  144.594022] iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_CNVI_ID
[  144.594067] iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_CNVR_ID
[  144.594114] iwlwifi 0000:02:00.0: 0x00000000 | CNVI_AUX_MISC_CHIP
[  144.594161] iwlwifi 0000:02:00.0: 0x00000000 | CNVR_AUX_MISC_CHIP
[  144.594207] iwlwifi 0000:02:00.0: 0x00000000 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[  144.594254] iwlwifi 0000:02:00.0: 0x00000000 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[  144.594308] iwlwifi 0000:02:00.0: Collecting data: trigger 2 fired.
[  165.042760] iwlwifi 0000:02:00.0: regular scan timed out
[  165.042955] iwlwifi 0000:02:00.0: Microcode SW error detected.  Restarting 0x2000000.
[  165.043201] iwlwifi 0000:02:00.0: Start IWL Error Log Dump:
[  165.043204] iwlwifi 0000:02:00.0: Status: 0x00000040, count: 6
[  165.043207] iwlwifi 0000:02:00.0: Loaded firmware version: 29.1654887522.0 3168-29.ucode
[  165.043211] iwlwifi 0000:02:00.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
[  165.043214] iwlwifi 0000:02:00.0: 0x000002B0 | trm_hw_status0
[  165.043216] iwlwifi 0000:02:00.0: 0x00000000 | trm_hw_status1
[  165.043219] iwlwifi 0000:02:00.0: 0x00043D6C | branchlink2
[  165.043221] iwlwifi 0000:02:00.0: 0x0004AFA2 | interruptlink1
[  165.043223] iwlwifi 0000:02:00.0: 0x0004AFA2 | interruptlink2
[  165.043225] iwlwifi 0000:02:00.0: 0x00000000 | data1
[  165.043227] iwlwifi 0000:02:00.0: 0x00000080 | data2
[  165.043230] iwlwifi 0000:02:00.0: 0x07030000 | data3
[  165.043232] iwlwifi 0000:02:00.0: 0x89002905 | beacon time
[  165.043234] iwlwifi 0000:02:00.0: 0xB5A886FA | tsf low
[  165.043235] iwlwifi 0000:02:00.0: 0x00000000 | tsf hi
[  165.043237] iwlwifi 0000:02:00.0: 0x00000000 | time gp1
[  165.043239] iwlwifi 0000:02:00.0: 0x0134F25F | time gp2
[  165.043241] iwlwifi 0000:02:00.0: 0x00000001 | uCode revision type
[  165.043243] iwlwifi 0000:02:00.0: 0x0000001D | uCode version major
[  165.043245] iwlwifi 0000:02:00.0: 0x62A39462 | uCode version minor
[  165.043246] iwlwifi 0000:02:00.0: 0x00000220 | hw version
[  165.043248] iwlwifi 0000:02:00.0: 0x00C89200 | board version
[  165.043250] iwlwifi 0000:02:00.0: 0x0000001C | hcmd
[  165.043252] iwlwifi 0000:02:00.0: 0x00022002 | isr0
[  165.043254] iwlwifi 0000:02:00.0: 0x00000000 | isr1
[  165.043255] iwlwifi 0000:02:00.0: 0x0000000A | isr2
[  165.043257] iwlwifi 0000:02:00.0: 0x00417CC0 | isr3
[  165.043259] iwlwifi 0000:02:00.0: 0x00000000 | isr4
[  165.043261] iwlwifi 0000:02:00.0: 0x0B8F001C | last cmd Id
[  165.043263] iwlwifi 0000:02:00.0: 0x00000000 | wait_event
[  165.043264] iwlwifi 0000:02:00.0: 0x00000080 | l2p_control
[  165.043266] iwlwifi 0000:02:00.0: 0x00010020 | l2p_duration
[  165.043268] iwlwifi 0000:02:00.0: 0x0000003F | l2p_mhvalid
[  165.043270] iwlwifi 0000:02:00.0: 0x000000CE | l2p_addr_match
[  165.043272] iwlwifi 0000:02:00.0: 0x00000005 | lmpm_pmg_sel
[  165.043273] iwlwifi 0000:02:00.0: 0x16070617 | timestamp
[  165.043275] iwlwifi 0000:02:00.0: 0x0034C8D0 | flow_handler
[  165.043387] iwlwifi 0000:02:00.0: Fseq Registers:
[  165.043434] iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_ERROR_CODE
[  165.043481] iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_TOP_INIT_VERSION
[  165.043527] iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_CNVIO_INIT_VERSION
[  165.043574] iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_OTP_VERSION
[  165.043620] iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_TOP_CONTENT_VERSION
[  165.043666] iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_ALIVE_TOKEN
[  165.043712] iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_CNVI_ID
[  165.043758] iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_CNVR_ID
[  165.043804] iwlwifi 0000:02:00.0: 0x00000000 | CNVI_AUX_MISC_CHIP
[  165.043851] iwlwifi 0000:02:00.0: 0x00000000 | CNVR_AUX_MISC_CHIP
[  165.043898] iwlwifi 0000:02:00.0: 0x00000000 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[  165.043944] iwlwifi 0000:02:00.0: 0x00000000 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[  165.043996] iwlwifi 0000:02:00.0: Collecting data: trigger 2 fired.
[  185.501784] iwlwifi 0000:02:00.0: regular scan timed out
[  185.502006] iwlwifi 0000:02:00.0: Microcode SW error detected.  Restarting 0x2000000.
[  185.502248] iwlwifi 0000:02:00.0: Start IWL Error Log Dump:
[  185.502251] iwlwifi 0000:02:00.0: Status: 0x00000040, count: 6
[  185.502254] iwlwifi 0000:02:00.0: Loaded firmware version: 29.1654887522.0 3168-29.ucode
[  185.502258] iwlwifi 0000:02:00.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
[  185.502261] iwlwifi 0000:02:00.0: 0x000002A0 | trm_hw_status0
[  185.502263] iwlwifi 0000:02:00.0: 0x00000000 | trm_hw_status1
[  185.502266] iwlwifi 0000:02:00.0: 0x00043D6C | branchlink2
[  185.502268] iwlwifi 0000:02:00.0: 0x0004AFA2 | interruptlink1
[  185.502270] iwlwifi 0000:02:00.0: 0x0004AFA2 | interruptlink2
[  185.502272] iwlwifi 0000:02:00.0: 0x00000000 | data1
[  185.502274] iwlwifi 0000:02:00.0: 0x00000080 | data2
[  185.502277] iwlwifi 0000:02:00.0: 0x07030000 | data3
[  185.502279] iwlwifi 0000:02:00.0: 0x86803393 | beacon time
[  185.502281] iwlwifi 0000:02:00.0: 0xB6E0FC6B | tsf low
[  185.502283] iwlwifi 0000:02:00.0: 0x00000000 | tsf hi
[  185.502285] iwlwifi 0000:02:00.0: 0x00000000 | time gp1
[  185.502287] iwlwifi 0000:02:00.0: 0x013539A4 | time gp2
[  185.502289] iwlwifi 0000:02:00.0: 0x00000001 | uCode revision type
[  185.502291] iwlwifi 0000:02:00.0: 0x0000001D | uCode version major
[  185.502294] iwlwifi 0000:02:00.0: 0x62A39462 | uCode version minor
[  185.502296] iwlwifi 0000:02:00.0: 0x00000220 | hw version
[  185.502298] iwlwifi 0000:02:00.0: 0x00C89200 | board version
[  185.502300] iwlwifi 0000:02:00.0: 0x0000001C | hcmd
[  185.502302] iwlwifi 0000:02:00.0: 0x00022002 | isr0
[  185.502304] iwlwifi 0000:02:00.0: 0x00000000 | isr1
[  185.502306] iwlwifi 0000:02:00.0: 0x00000002 | isr2
[  185.502308] iwlwifi 0000:02:00.0: 0x0041C4C0 | isr3
[  185.502310] iwlwifi 0000:02:00.0: 0x00000000 | isr4
[  185.502312] iwlwifi 0000:02:00.0: 0x863F009D | last cmd Id
[  185.502315] iwlwifi 0000:02:00.0: 0x00000000 | wait_event
[  185.502317] iwlwifi 0000:02:00.0: 0x000000D4 | l2p_control
[  185.502319] iwlwifi 0000:02:00.0: 0x00018020 | l2p_duration
[  185.502321] iwlwifi 0000:02:00.0: 0x00000007 | l2p_mhvalid
[  185.502323] iwlwifi 0000:02:00.0: 0x00000081 | l2p_addr_match
[  185.502325] iwlwifi 0000:02:00.0: 0x00000005 | lmpm_pmg_sel
[  185.502327] iwlwifi 0000:02:00.0: 0x16070617 | timestamp
[  185.502329] iwlwifi 0000:02:00.0: 0x0034C8E0 | flow_handler
[  185.502442] iwlwifi 0000:02:00.0: Fseq Registers:
[  185.502488] iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_ERROR_CODE
[  185.502535] iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_TOP_INIT_VERSION
[  185.502581] iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_CNVIO_INIT_VERSION
[  185.502629] iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_OTP_VERSION
[  185.502676] iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_TOP_CONTENT_VERSION
[  185.502723] iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_ALIVE_TOKEN
[  185.502768] iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_CNVI_ID
[  185.502814] iwlwifi 0000:02:00.0: 0x00000000 | FSEQ_CNVR_ID
[  185.502860] iwlwifi 0000:02:00.0: 0x00000000 | CNVI_AUX_MISC_CHIP
[  185.502907] iwlwifi 0000:02:00.0: 0x00000000 | CNVR_AUX_MISC_CHIP
[  185.502953] iwlwifi 0000:02:00.0: 0x00000000 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[  185.502999] iwlwifi 0000:02:00.0: 0x00000000 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[  185.503054] iwlwifi 0000:02:00.0: Collecting data: trigger 2 fired.
