13
I hid some files using the command:
mv * .*
but now I am unable to find them. I tried using:
mv .* *
but nothing happened (an error was shown). If I run:
ls -la
it's showing:
total 8
drwxrwxr-x 2 abhishek abhishek 4096 Mar  9 20:46 .
drwxrwxr-x 4 abhishek abhishek 4096 Mar  9 20:46 ..
Is there any way to recover my hidden files?
Your files are not hidden, you have moved all files (and directories if any) one directory up.
This happens because mv * .* won't work as you think it will. The command mv will only move one file to one file (rename) or move one or multiple files to a directory. It won't move multiple files to multiple files with some smart renaming.
What happened?
Let's assume we have one directory and 3 files in our directory:
dir1
file1
file2
file3
Some Shells (e.g. bash, dash, ...) will expand your command to:
mv dir1 file1 file2 file3 . ..
Your expanded command fits the second form of the SYNOPSIS you find at man mv:
mv [OPTION]... SOURCE... DIRECTORY
Note the . and ..:
  • . is the current directory,
  • .. is one directory up.
The command means: move dir1, file1, file2 and file3 and . to ..; It will also essentially give an error, something like:
mv: cannot move '.' to '../.'
But given you have write permission in that directory, all other files have been moved. You can find your files in .. (= one directory up). However, files with same name have been overwritten and you won't know which files was in which directory before.
If you had a subdirectory .hidden-dir, it would have expanded to:
mv dir1 file1 file2 file3 . .. .hidden-dir
Then, all files would have been moved to .hidden-dir. However, this seems not the case for you, because the you would have seen .hidden-dir in your ls -la output.
How to fix
Run:
mv ../dir1 ../file1 ../file2 ../file3 .
However, you need to know the names.
What you should have used
mmv '*' '.#1'
or
rename 's/^/./' *
pLumo
  • 27,991
