10
Updated from 11.10 to 12.04 after fresh install, often the lock screen will give me a black screen with a mouse cursor instead of the usual. This occurs most often while the Ubuntu software center is open or left unattended for a long period of time.
I have a mouse cursor I can move and even select the area where I would enter my password. If typed in and I press enter I can no longer select the text area like it logged in, yet still have a black screen.
I can enter the terminal and the Ctrl+Alt+Del to restart the computer in order to get back in. Is there any fix for this or a way to get back to the GUI without restarting the whole computer?
5 Answers5
I narrowed this problem down to being exclusively related to Software Center running. Removing and reinstalling Software Center solved this issue.
Get to the terminal and try to type:
sudo restart lightdm
This will erase all unsaved work but it will restart the display manager, and will let you to login again.
LiquidPL
  • 218
Relatively easy solution is to do ALT+PrintScr/SysRq+K You get log off
But hope that this is temporarely solution
milos
I've again had this same issue so reinstalling SW Center hasn't worked. But a quick fix on the black screen is to press Ctrl Alt F1, and then Ctrl Alt F7. The logon screen then appears with its GUI.
nLinked
  • 3,387
Solved. Disable automatic screen lock in "Brightness & Lock" settings. If it doesn't work for you (mine froze screen after wakeup), try installing xfce but keep using unity. Notifications changed a bit, but freezing problem disappeared.
Pepos
