I'm preparing a Lubuntu installation on a computer I'm planning to give away, using the OEM install mode so that I can pre-install various apps but still let the recipient create their user account using the intro wizard.
By default, Lubuntu (or specifically, Openbox) has virtual desktops, which it's easy to accidentally switch between with the mouse wheel. I can easily fix this for the OEM user in the Openbox Configuration Manager, but how can I make it the default for new users?
Openbox stores its settings in an XML file. For already-created users, this is found at ~/.config/openbox/lxqt-rc.xml (or .../lubuntu-rc.xml on 18.04), which you can modify to test out your changes. However, to make your changes apply to new users as well, you need to edit the XML file that will be applied to new users. This is located at /etc/xdg/xdg-Lubuntu/openbox/lxqt-rc.xml (or /usr/share/lubuntu/openbox/rc.xml on 18.04).
For your specific example of disabling virtual desktops, you need to change the <number> tag in the <desktops> section to 1:
<desktops>
  <number>2</number>   <!-- change this line -->
  <firstdesk>1</firstdesk>
I'd suggest making the change to ~/.config/openbox/lubuntu-rc.xml, logging out and back in to check that it does what you expect, then copying it to be the default:
sudo cp ~/.config/openbox/lxqt-rc.xml /etc/xdg/xdg-Lubuntu/openbox/lxqt-rc.xml
Or, on 18.04:
sudo cp ~/.config/openbox/lubuntu-rc.xml /usr/share/lubuntu/openbox/rc.xml
