How to install Windows 10 on ubuntu 20.04 using VirtualBox?
Some Things to Help Windows Run Better on VirtualBox
Here are some things that work for me.
  • Create your machine using a fixed size disk
  • Allocate more memory
  • Install Guest Additions
  • Install Extension Packs
  • Enable copy paste
  • Increase display memory
  • Allocate more CPUs
  • Ensure Intel VT-x or AMD-V is enabled
  • Enable 2D / 3D acceleration
  • Suspend instead of shutting down
  • Use the Intel PRO/1000 network drivers if using a network
Zanna
  • 72,312
C.S.Cameron
  • 20,530
  • 78
  • 125
You probably already know this, but VirtualBox comes with a command called vboxmanage.
Here is a script that installs the evaluation copy of Windows 10 Enterprise. There is a link in the comments of the code below where you can download the evaluation ISO.
I just ran this script in order to install Windows 10 Enterprise (Evaluation Copy) on Ubuntu 22.04 using the VirtualBox version 17.0
https://gist.github.com/angstyloop/80cea18f767562351ab5f9917cf3f1ec
#!/bin/sh
create-windows-enterprise-vm-from-iso.sh
Use VBoxManage to create a VirtualBox VM from an evaluation copy of Windows 10
Enterprise ISO.
Follow the download instructions for your region at
https://www.microsoft.com/en-us/evalcenter/download-windows-10-enterprise
Create a virtual machine named "windows-10-enterprise-bob" from and ISO
name=windows-10-enterprise-bob
vboxmanage createvm --name $name --ostype Windows10_64 --register --basefolder pwd
Turn on IO APIC
vboxmanage modifyvm $name --ioapic on
Designate RAM size and video RAM size
vboxmanage modifyvm $name --memory 4096 --vram 128
Create an internal network interface connected to the internal network named
RedTeamLab
vboxmanage modifyvm $name --nic1 intnet --intnet1 RedTeamLab
Put the network interface in promiscuous mode
vboxmanage modifyvm $name --nicpromisc1 allow-all
vboxmanage createhd --filename pwd/$name/$name_DISK.vdi --size 60000 --format VDI vboxmanage storagectl $name --name 'SATA Controller' --add sata --controller IntelAhci vboxmanage storageattach $name --storagectl 'SATA Controller' --port 0 --device 0 --type hdd --medium pwd/$name/$name_DISK.vdi vboxmanage storagectl $name --name 'IDE Controller' --add ide --controller PIIX4 vboxmanage storageattach $name --storagectl 'IDE Controller' --port 1 --device 0 --type dvddrive --medium pwd/windows-10-enterprise.iso vboxmanage modifyvm $name --boot1 dvd --boot2 disk --boot3 none --boot4 none
#vboxmanage startvm $name
