I am trying to install libgtk-3-dev and receving the following message:
user@nvidia-jetson-tx2:~/projects/realsense/librealsense$ sudo apt-get install libgtk-3-dev
[sudo] password for user:
Reading package lists... Done
Building dependency tree
The following information may help resolve the situation:
libgtk-3-dev : Depends: libgtk-3-0 (= 3.22.30-1ubuntu1) but 3.22.30-1ubuntu4 is to be installed
Depends: gir1.2-gtk-3.0 (= 3.22.30-1ubuntu1) but 3.22.30-1ubuntu4 is to be installed
Depends: libpango1.0-dev (>= 1.40.5) but it is not going to be installed
Depends: libatk-bridge2.0-dev but it is not going to be installed
Depends: libcairo2-dev (>= 1.14.0) but it is not going to be installed
Depends: libxkbcommon-dev but it is not going to be installed
If my understanding is correct, the defined dependencies in libgtk-3-dev are looking for older version of libgtk-3-0 and gir1.2-gtk-3.0. What would be the best course of action for these two packages:
- donwgrade libgtk-3-0 and gir1.2-gtk-3.0
- force the installation of libgtk-3-dev by somehow ignoring the dependencies (not sure if this is possible at all)
- modify the dependency (if possible)
- something else?
What about the other 4 packages (libpango1.0-dev, libatk-bridge2.0-dev, libcairo2-dev, libxkbcommon-dev)? Where they not installed because version criteria for libgtk-3-0 and gir1.2-gtk-3.0 was not met or potentially there is some other issue with those as well?
Can anyone give me some guidence on how to proceed?
Thanks a lot in advance!
