using the following command
1.sudo apt update
2.sudo apt install mysql-server
Getting below error
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: mysql-server : Depends: mysql-server-5.7 but it is not going to be installed E: Unable to correct problems, you have held broken packages.
Any help ?
my friend. It seems you have a bug with repositories.
So first, remove all non-official repositories from the distribution. Or third-party repositories.
Then, run
sudo apt update
Then you can install MySQL 8 by adding the official repository
wget https://dev.mysql.com/get/mysql-apt-config_0.8.14-1_all.deb
sudo dpkg -i mysql-apt-config_0.8.14-1_all.deb
Refresh APT again
sudo apt update
And perform the MySQL installation
And also you can install the client.
Here is the reference.It should be enough.
