Here's the error I'm getting:
derek@derek-Satellite-C55-B:~$ sudo apt install tightvncserver
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
codeblocks-contrib : Depends: libboost-system1.67.0 but it is not going to be installed
Depends: libgamin0 but it is not going to be installed
Depends: libwxgtk3.0-0v5 (>= 3.0.4+dfsg) but it is not installable
Depends: libwxsmithlib0 (= 20.03) but 20.03-3 is to be installed
Depends: codeblocks (= 20.03) but 20.03-3 is to be installed
Recommends: valgrind but it is not going to be installed
Recommends: cppcheck but it is not going to be installed
Recommends: cscope but it is not going to be installed
Recommends: cccc but it is not going to be installed
codeblocks-libwxcontrib0 : Depends: libwxgtk3.0-0v5 (>= 3.0.4+dfsg) but it is not installable
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
I downloaded code::blocks yesterday, which came with a series of deb files I assumed to be dependencies. I started installing each, but realized that I wasn't going to get it installed with the download I had. Next I added a repository for code::blocks, never got code::blocks installed.
Now when I run sudo apt-get update, I get this error:
Hit:1 http://us.archive.ubuntu.com/ubuntu focal InRelease
Hit:2 http://us.archive.ubuntu.com/ubuntu focal-updates InRelease
Hit:3 http://us.archive.ubuntu.com/ubuntu focal-backports InRelease
Hit:4 https://download.sublimetext.com apt/dev/ InRelease
Hit:5 http://packages.microsoft.com/repos/code stable InRelease
Hit:6 http://downloads.metasploit.com/data/releases/metasploit-framework/apt lucid InRelease
Hit:7 https://packages.microsoft.com/ubuntu/16.04/prod xenial InRelease
Hit:8 http://dl.google.com/linux/chrome/deb stable InRelease
Ign:9 http://ppa.launchpad.net/codeblocks-devs/release/ubuntu focal InRelease
Hit:10 http://security.ubuntu.com/ubuntu focal-security InRelease
Err:11 http://ppa.launchpad.net/codeblocks-devs/release/ubuntu focal Release
404 Not Found [IP: 91.189.95.85 80]
Get:12 https://repo.protonvpn.com/debian unstable InRelease [2,521 B]
E: The repository 'http://ppa.launchpad.net/codeblocks-devs/release/ubuntu focal Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
And anything I try to install, I get an error:
derek@derek-Satellite-C55-B:~$ sudo apt-get install tightvncserver
Any help would be greatly appreciated as I don't want to have to reinstall... I've got everything right where I like it!
