Updated Ubuntu and I reinstall R and now if I tried to run R on my terminal I am getting below error, I am getting what will be the issue
/usr/local/lib/R/bin/exec/R: error while loading shared libraries: libreadline.so.7: cannot open shared object file: No such file or directory
I tried some threads still not able to resolve
libreadline.so.6 issue in ubuntu 18.04
$ which R
/usr/local/bin/R
$ R --version /usr/local/lib/R/bin/exec/R: error while loading shared libraries: libreadline.so.7: cannot open shared object file: No such file or directory
$ dpkg -l "libreadline*" dpkg-query: no packages found matching . dpkg-query: no packages found matching – Desired=Unknown/Install/Remove/Purge/Hold | Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad) ||/ Name Version Architecture Description +++-=====================-============-============-====================================================== un libreadline-common <none> <none> (no description available) ii libreadline-dev:amd64 8.0-4 amd64 GNU readline and history libraries, development files un libreadline-gplv2-dev <none> <none> (no description available) un libreadline4 <none> <none> (no description available) un libreadline5 <none> <none> (no description available) un libreadline5-dev <none> <none> (no description available) un libreadline6-dev <none> <none> (no description available) ii libreadline8:amd64 8.0-4 amd64 GNU readline and history libraries, run-time libraries
N0rbert
  • 103,263
To get more reproducible results I would recommend to remove locally installed R with
sudo rm /usr/local/bin/R
and then install version from the official repositories by
sudo apt-add-repository universe
sudo apt-get update
sudo apt-get install r-base-dev
then test the installation by running R --version.
N0rbert
  • 103,263
