it seems I am not able to upgrade from 450 driver to 460. Following is the output:
$ nvidia-smi
Tue Mar  2 10:12:34 2021
| NVIDIA-SMI 450.102.04   Driver Version: 450.102.04   CUDA Version: 11.0     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  GeForce GTX 1050    Off  | 00000000:01:00.0 Off |                  N/A |
| N/A   64C    P0    N/A /  N/A |   1086MiB /  2000MiB |     36%      Default |
|                               |                      |                  N/A |
+-----------------------------------------------------------------------------+ | Processes: | | GPU GI CI PID Type Process name GPU Memory | | ID ID Usage | |=============================================================================| | 0 N/A N/A 1421 G /usr/lib/xorg/Xorg 192MiB | | 0 N/A N/A 6321 G /usr/lib/xorg/Xorg 459MiB | | 0 N/A N/A 6494 G /usr/bin/gnome-shell 332MiB | | 0 N/A N/A 7090 G /usr/lib/firefox/firefox 1MiB | | 0 N/A N/A 8188 G /usr/lib/firefox/firefox 1MiB | | 0 N/A N/A 9017 G /usr/lib/firefox/firefox 1MiB | | 0 N/A N/A 9064 G /usr/lib/firefox/firefox 1MiB | | 0 N/A N/A 9227 G /usr/lib/firefox/firefox 1MiB | | 0 N/A N/A 9731 G /usr/lib/firefox/firefox 1MiB | | 0 N/A N/A 12448 G /usr/lib/firefox/firefox 1MiB | | 0 N/A N/A 24608 G /usr/lib/firefox/firefox 1MiB | | 0 N/A N/A 99825 G .../.steam/ubuntu12_32/steam 33MiB | | 0 N/A N/A 99834 G ./steamwebhelper 1MiB | | 0 N/A N/A 99847 G ...AAAAAAAgAAAAAAAAA --log-f 39MiB | +-----------------------------------------------------------------------------+ $ sudo apt install nvidia-driver-460 Reading package lists... Done Building dependency tree
Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help resolve the situation:
The following packages have unmet dependencies: nvidia-driver-460 : Depends: libnvidia-gl-460 (= 460.39-0ubuntu0.20.04.1) but it is not going to be installed Depends: libnvidia-extra-460 (= 460.39-0ubuntu0.20.04.1) but it is not going to be installed Depends: nvidia-compute-utils-460 (= 460.39-0ubuntu0.20.04.1) but it is not going to be installed Depends: libnvidia-decode-460 (= 460.39-0ubuntu0.20.04.1) but it is not going to be installed Depends: libnvidia-encode-460 (= 460.39-0ubuntu0.20.04.1) but it is not going to be installed Depends: nvidia-utils-460 (= 460.39-0ubuntu0.20.04.1) but it is not going to be installed Depends: xserver-xorg-video-nvidia-460 (= 460.39-0ubuntu0.20.04.1) but it is not going to be installed Depends: libnvidia-cfg1-460 (= 460.39-0ubuntu0.20.04.1) but it is not going to be installed Depends: libnvidia-ifr1-460 (= 460.39-0ubuntu0.20.04.1) but it is not going to be installed Depends: libnvidia-fbc1-460 (= 460.39-0ubuntu0.20.04.1) but it is not going to be installed Recommends: libnvidia-decode-460:i386 (= 460.39-0ubuntu0.20.04.1) Recommends: libnvidia-encode-460:i386 (= 460.39-0ubuntu0.20.04.1) Recommends: libnvidia-ifr1-460:i386 (= 460.39-0ubuntu0.20.04.1) Recommends: libnvidia-fbc1-460:i386 (= 460.39-0ubuntu0.20.04.1) Recommends: libnvidia-gl-460:i386 (= 460.39-0ubuntu0.20.04.1)
I checked online and people say to do purge first, but I suspect that it won't work. I am wondering is there anyone went through the path of this upgrade? Or should I wait for the next driver?
Terrance
  • 43,712
Jason Hu
  • 133
You may try sudo apt --fix-broken install but I am not sure if it'll solve your problem.
Why do you suspect this? Per nvidia docs you have to purge the older version before you can install a new one. Try:
sudo apt purge nvidia-*
sudo apt autoremove
You might have to restart at this point (If you get a blank screen, don't panic. You can login using alt-ctrl-F1 and install the new nvidia driver or switch to using nouveau till your install is done)
