I am attempting to debug a SIGSEGV on PHP on my Ubuntu 9.10.
I've installed php5-dbg to have the debug symbols available, however, when I start gdb, it shows the following output:
Reading symbols from /usr/bin/php...
Reading symbols from /usr/lib/debug/usr/bin/php5...done.
(no debugging symbols found)...done.
Any ideas are welcome.
kenorb
  • 10,944
Johnco
  • 215
Under certain situations, the -dbg packages don't work correctly. Instead, try the -dbgsym packages, available from the separate "debug symbols" repository:
https://wiki.ubuntu.com/DebuggingProgramCrash
However, when trying this locally with Ubuntu 9.10, I have no problem loading symbols using the existing php5-dbg package. Perhaps make sure you have the latest updates installed first, and then try it?
As an example:
$ cat /tmp/test.php
<?php sleep(10); ?>
$ gdb php
(gdb) run /tmp/test.php
^C
Program received signal SIGINT, Interrupt.
0xf7fe0430 in __kernel_vsyscall ()
(gdb) bt
#0  0xf7fe0430 in __kernel_vsyscall ()
#1  0xf7a13b50 in nanosleep () from /lib/tls/i686/cmov/libc.so.6
#2  0xf7a13991 in sleep () from /lib/tls/i686/cmov/libc.so.6
#3  0x081fbfc1 in zif_sleep (ht=1, return_value=0x866d204,
    return_value_ptr=0x0, this_ptr=0x0, return_value_used=0)
    at /build/buildd/php5-5.2.10.dfsg.1/ext/standard/basic_functions.c:4787
#4  0x082f9616 in zend_do_fcall_common_helper_SPEC (execute_data=0xffffafbc)
    at /build/buildd/php5-5.2.10.dfsg.1/Zend/zend_vm_execute.h:200
#5  0x082f511b in execute (op_array=0x866d7f0)
    at /build/buildd/php5-5.2.10.dfsg.1/Zend/zend_vm_execute.h:92
#6  0x082cf414 in zend_execute_scripts (type=8, retval=0x0, file_count=3)
    at /build/buildd/php5-5.2.10.dfsg.1/Zend/zend.c:1215
#7  0x08284166 in php_execute_script (primary_file=0xffffd454)
    at /build/buildd/php5-5.2.10.dfsg.1/main/main.c:2046
#8  0x08352c38 in main (argc=2, argv=0xffffd554)
    at /build/buildd/php5-5.2.10.dfsg.1/sapi/cli/php_cli.c:1170
Kees Cook
  • 17,823
