I'm trying to follow the steps in this answer to make this USB wi-fi adaptor work on my Ubuntu 20.04 laptop, but get an error message.
This is how the device has been detected by the system:
$ lsusb | grep 802
Bus 001 Device 006: ID 0bda:c811 Realtek Semiconductor Corp. 802.11ac NIC
Other answers on here indicate that the above ID means I want the rtl8821CU driver. This apparently builds and installs fine:
$ git clone https://github.com/brektrou/rtl8821CU.git
$ cd rtl8821CU
$ sudo ./dkms-install.sh
About to run dkms install steps...
Creating symlink /var/lib/dkms/rtl8821CU/5.4.1/source ->
/usr/src/rtl8821CU-5.4.1
DKMS: add completed.
Kernel preparation unnecessary for this kernel. Skipping...
Building module:
cleaning build area...
'make' KVER=5.4.0-66-generic.....................................................
DKMS: build completed.
8821cu.ko:
Running module version sanity check.
- Original module
- No original module exists within this kernel
- Installation
- Installing to /lib/modules/5.4.0-66-generic/updates/dkms/
depmod....
DKMS: install completed.
Finished running dkms install steps.
But then at the final step, it can't be found:
$ sudo modprobe 88212cu
modprobe: FATAL: Module 88212cu not found in directory /lib/modules/5.4.0-66-generic
What should I try next? Thank you.
