Let's say I want to create an alias called ss for the command sudo -s. But ss is already an existing command, so I want to create another alias called sst for the command ss.
If using just the normal command names, this is not possible, since aliases:
- Are not set in a way that respects the order, and
- Reference other aliases, instead of only referencing commands
So if I try the following:
alias sst='ss'
alias ss='sudo -s'
Running the command sst results in running sudo -s, which is not my intention.
How can this be done?
