I'm currently stuck and cannot install mono-devel on my PC. I've installed the mono keyring and repo, but whenever I try to install it I get this:
The following packages have unmet dependencies: mono-devel : Depends: mono-runtime (>= 3.0~) but it is not going to be installed Depends: libc6 (>= 2.31) but 2.28-10 is to be installed or libc6.1 (>= 2.31) but it is not installable or libc0.1 (>= 2.31) but it is not installable Depends: libglib2.0-0 (>= 2.64.6) but 2.58.3-2+deb10u2 is to be installed Depends: libmono-cecil-private-cil (>= 6.12.0.122) but it is not going to be installed Depends: libmono-cecil-private-cil (< 6.12.0.123) but it is not going to be installed Depends: libmono-codecontracts4.0-cil (>= 1.0) but it is not going to be installed Depends: libmono-compilerservices-symbolwriter4.0-cil (>= 3.6.0) but it is not going to be installed Depends: libmono-corlib4.5-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-peapi4.0a-cil (>= 3.2.8) but it is not going to be installed Depends: libmono-relaxng4.0-cil (>= 2.10.1) but it is not going to be installed Depends: libmono-security4.0-cil (>= 3.0.6) but it is not going to be installed Depends: libmono-system-configuration-install4.0-cil (>= 1.0) but it is not going to be installed Depends: libmono-system-configuration4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-core4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-data4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-drawing4.0-cil (>= 3.0.6) but it is not going to be installed Depends: libmono-system-io-compression-filesystem4.0-cil (>= 3.2.1) but it is not going to be installed Depends: libmono-system-runtime-serialization4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-runtime4.0-cil (>= 2.10.1) but it is not going to be installed Depends: libmono-system-security4.0-cil (>= 1.0) but it is not going to be installed Depends: libmono-system-servicemodel4.0a-cil (>= 3.2.3) but it is not going to be installed Depends: libmono-system-web-services4.0-cil (>= 1.0) but it is not going to be installed Depends: libmono-system-xml-linq4.0-cil (>= 3.0.6) but it is not going to be installed Depends: libmono-system-xml4.0-cil (>= 3.12.0) but it is not going to be installed Depends: libmono-system4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: mono-mcs (= 6.12.0.122-0xamarin1+ubuntu2004b1) but it is not going to be installed Depends: mono-roslyn (= 6.12.0.122-0xamarin1+ubuntu2004b1) but it is not going to be installed Depends: mono-gac (= 6.12.0.122-0xamarin1+ubuntu2004b1) but it is not going to be installed Depends: mono-xbuild (= 6.12.0.122-0xamarin1+ubuntu2004b1) but it is not going to be installed Depends: libmono-cil-dev (= 6.12.0.122-0xamarin1+ubuntu2004b1) but it is not going to be installed Depends: libmono-2.0-dev (>= 6.12.0.122-0xamarin1+ubuntu2004b1) but it is not going to be installed Depends: libmono-2.0-dev (< 6.12.0.122-0xamarin1+ubuntu2004b1.1~) but it is not going to be installed Depends: ca-certificates-mono (= 6.12.0.122-0xamarin1+ubuntu2004b1) but it is not going to be installed E: Unable to correct problems, you have held broken packages.
Please help, thank you all.
sully
Install the version that is built for your system not the latest one available. You have a 20.04 system trying to install packages built for at least the 20.10 going from the libc6 error. When you add a repository to your install they need to be of the same release or they will never install.
