I used to have squid installed. And I wanted to clean up to have the default config.
I did:
apt remove squid --auto-remove
Reading package lists... Done
Building dependency tree
The following packages will be REMOVED:
libecap3 libnetfilter-conntrack3 libpython3-dev libpython3.5-dev python3-dev python3-wheel python3.5-dev squid squid-common squid-langpack
0 upgraded, 0 newly installed, 10 to remove and 288 not upgraded.
After this operation, 65.1 MB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 161441 files and directories currently installed.)
Removing squid (3.5.12-1ubuntu7.10) ...
Removing libecap3:amd64 (1.0.1-3ubuntu3) ...
Removing libnetfilter-conntrack3:amd64 (1.0.5-1) ...
Removing python3-dev (3.5.1-3) ...
Removing libpython3-dev:amd64 (3.5.1-3) ...
Removing python3.5-dev (3.5.2-2ubuntu0~16.04.8) ...
Removing libpython3.5-dev:amd64 (3.5.2-2ubuntu0~16.04.8) ...
Removing python3-wheel (0.29.0-1) ...
Removing squid-common (3.5.12-1ubuntu7.10) ...
Removing squid-langpack (20150704-1) ...
Processing triggers for man-db (2.7.5-1) ...
Processing triggers for libc-bin (2.23-0ubuntu10) ...
But then I noticed that /etc/squid/squid.conf still there, and I manually deleted it and tried to reinstall again
sudo apt install squid
The following additional packages will be installed:
libecap3 libnetfilter-conntrack3 squid-common squid-langpack
Suggested packages:
squidclient squid-cgi squid-purge smbclient winbindd
The following NEW packages will be installed:
libecap3 libnetfilter-conntrack3 squid squid-common squid-langpack
0 upgraded, 5 newly installed, 0 to remove and 288 not upgraded.
Need to get 2,499 kB/2,698 kB of archives.
After this operation, 11.0 MB of additional disk space will be used.
Get:1 http://mirrors.cloud.aliyuncs.com/ubuntu xenial-updates/main amd64 squid-common all 3.5.12-1ubuntu7.15 [176 kB]
Get:2 http://mirrors.cloud.aliyuncs.com/ubuntu xenial-updates/main amd64 squid amd64 3.5.12-1ubuntu7.15 [2,323 kB]
Fetched 2,499 kB in 0s (3,684 kB/s)
Selecting previously unselected package libecap3:amd64.
(Reading database ... 158955 files and directories currently installed.)
Preparing to unpack .../libecap3_1.0.1-3ubuntu3_amd64.deb ...
Unpacking libecap3:amd64 (1.0.1-3ubuntu3) ...
Selecting previously unselected package libnetfilter-conntrack3:amd64.
Preparing to unpack .../libnetfilter-conntrack3_1.0.5-1_amd64.deb ...
Unpacking libnetfilter-conntrack3:amd64 (1.0.5-1) ...
Selecting previously unselected package squid-langpack.
Preparing to unpack .../squid-langpack_20150704-1_all.deb ...
Unpacking squid-langpack (20150704-1) ...
Selecting previously unselected package squid-common.
Preparing to unpack .../squid-common_3.5.12-1ubuntu7.15_all.deb ...
Unpacking squid-common (3.5.12-1ubuntu7.15) ...
Selecting previously unselected package squid.
Preparing to unpack .../squid_3.5.12-1ubuntu7.15_amd64.deb ...
Unpacking squid (3.5.12-1ubuntu7.15) ...
Processing triggers for systemd (229-4ubuntu21.9) ...
Processing triggers for ureadahead (0.100.0-19) ...
Processing triggers for ufw (0.35-0ubuntu2) ...
Setting up libecap3:amd64 (1.0.1-3ubuntu3) ...
Setting up libnetfilter-conntrack3:amd64 (1.0.5-1) ...
Setting up squid-langpack (20150704-1) ...
Setting up squid-common (3.5.12-1ubuntu7.15) ...
Setting up squid (3.5.12-1ubuntu7.15) ...
Installing new version of config file /etc/resolvconf/update-libc.d/squid ...
insserv: warning: current start runlevel(s) (empty) of script `squid' overrides LSB defaults (2 3 4 5).
insserv: warning: current stop runlevel(s) (0 1 2 3 4 5 6) of script `squid' overrides LSB defaults (0 1 6).
insserv: can not symlink(../init.d/aegis, ../rc2.d/S03aegis): File exists
insserv: can not symlink(../init.d/aegis, ../rc3.d/S03aegis): File exists
insserv: can not symlink(../init.d/aegis, ../rc4.d/S03aegis): File exists
insserv: can not symlink(../init.d/aegis, ../rc5.d/S03aegis): File exists
Skipping profile in /etc/apparmor.d/disable: usr.sbin.squid
But then I noticed that at the very end of the output above, some files exist and I am not sure it was installed properly. Hence, I tried again to force an installation:
# apt-get --reinstall install squid
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 288 not upgraded.
Need to get 2,323 kB of archives.
After this operation, 0 B of additional disk space will be used.
Get:1 http://mirrors.cloud.aliyuncs.com/ubuntu xenial-updates/main amd64 squid amd64 3.5.12-1ubuntu7.15 [2,323 kB]
Fetched 2,323 kB in 0s (5,468 kB/s)
(Reading database ... 161235 files and directories currently installed.)
Unpacking squid (3.5.12-1ubuntu7.15) over (3.5.12-1ubuntu7.15) ...
But it seems nothing is installed.
Then, I checked to make sure the package actually contains the file:
# apt-file list squid | grep conf
biosquid-dev: /usr/include/biosquid/squidconf.h
biosquid-dev: /usr/share/doc/biosquid-dev/examples/Testsuite/sqdconfig_main.c
lightsquid: /etc/apache2/conf-available/lightsquid.conf
squid: /etc/resolvconf/update-libc.d/squid
squid: /etc/squid/squid.conf
squid-cgi: /etc/squid/cachemgr.conf
squid-common: /usr/share/doc/squid-common/squid.conf.documented.gz
squid-common: /usr/share/squid/mime.conf
squid-deb-proxy: /etc/init/squid-deb-proxy.conf
squid-deb-proxy: /etc/resolvconf/update-libc.d/squid-deb-proxy
squid-deb-proxy: /etc/squid-deb-proxy/squid-deb-proxy.conf
squid-deb-proxy-client: /etc/apt/apt.conf.d/30autoproxy
squidguard: /etc/squidguard/squidGuard.conf.default
squidguard: /usr/share/doc/squidguard/examples/sample.conf
squidguard: /usr/share/doc/squidguard/examples/time-config.txt
squidguard-doc: /usr/share/doc/squidguard-doc/doc/configuration.txt.gz
squidguard-doc: /usr/share/doc/squidguard-doc/doc/configure.txt.gz
squidguard-doc: /usr/share/doc/squidguard-doc/html/configure.html
squidtaild: /etc/squidtaild/squidtaild.conf
It is in the package but not on my box:
# ll /etc/squid/squid.conf
ls: cannot access '/etc/squid/squid.conf': No such file or directory
Any idea how to fix this?
Thanks!
